PV2EV
For some of what I do on the farm I tow a simple implement. For other work an implement uses the PTO, and needs a 3 point hitch connection only because the PTO. In the rare case, an implement absolutely requires a 3 point hitch. And for some orchard work there are task specific vehicles that could be a towed implement if done differently.
Assuming 30A ProPower (8HP) would be enough, I think some of the these implements could be converted to a towed electrical solution, saving a huge amount of diesel if towed behind a Lightning Pro.
An example would a large rotary mower. Replace the gearbox with an electric motor and you are good to go. You may/would have to find a way to float the hitch? And if having to backup, not jackknife, which is not a problem with a 3 point hitch. The place the Pro not work is very poor fields, or sloped terrain.
I only post this as the few electric tractor solutions are lacking (mostly capacity/power).
