Cheapest home power solution w/o Charge Station Pro
hihosilver
Len
New Jersey
2022 Lightning Lariat - SR - Oxford White - MaxTow
So I would like to know what most of the SR Lightning owners are doing or planning; if they intend to power their homes with the truck. I am trying to keep this as simple and cheap as possible and create a solution that will power my home from any potential external source such as a generator, battery array and of course the truck. My thoughts at present are a generator interlock kit on my 200 Amp service with a dual pole 60 amp breaker, install an outdoor rated box on my homes exterior with a Nema twist lock L14-30p connection and get a decent generator cord to go from the truck's Power Pro 240 connection to the house. The only expertise required to operate this setup would be to know how to manage the amperage load of your home and only turn on breakers for essential items.
FlasherZ
St. Louis Metro
That is the way I would recommend - it's safe and the right way to do what you're trying to do for the lowest cost.
Only one nitpick - if it's a 30A L14-30P inlet, then you need to protect it with a 30A breaker, not a 60A.
jefro
F150, Corvette, Bolt EV,
Cheapest would be to use the bed or frunk outlets I'd think. Ford is holding V2X output a fee for SR the creeps.
hihosilver
hihosilver
Len
New Jersey
your panel needs a seperation of system ground and neutral
Thanks for the advice! Is there a possibility that what I think is my main panel is actually a sub panel and therefore I may already have ground and neutrals separated? I have a solar system and I'll attach a picture of my meter and a disconnect mounted on the exterior of the house.
Ford F-150 Lightning Cheapest home power solution w/o Charge Station Pro IMG_3959
the simplest/easiest way to access power from the truck is simply by using standard extension cords... it's not the most automated or 'pretty' way, but it still gets the job done. in times of catastrophe, or a simply outage, there's usually little need for any more.
hihosilver
hihosilver
Len
New Jersey
I think I answered my own question by looking in the panel. It is the main (first disconnect) and that shutoff is going to the solar system. Damn. Pardon my dumb questions, but why does the truck not function like a generator would? Is it sensing that lack of an isolated ground?
Ford F-150 Lightning Cheapest home power solution w/o Charge Station Pro IMG_3961
VTbuckeye
Vermont
Ground and neutral being connected in the electrical box looks to the lightning as a ground fault.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
That's what I am going to do.
Lots of heavy duty extension cords to the house if needed.
We don't get power outages at all where I am at, but then our electricity rates are sky high...
RangerJ
CA
Ranger
For Lightning w 2.4kW (w/o 9.6kW Pro Power), perhaps a 120v manual transfer switch (eg Amz asin B00FADDE0A- switch both legs) using one for ea critical circuit only (furnace, fridge, etc), ea run to a 120 on truck w proper gauge ext cord. Keep the basics running on a budget…​
sotek2345
Engineering Manager
Depends how your house is set up. Extension cords can certainly help, but the circulation pump for my hot water furnace is hard wired, so I wouldn't be able to switch that to a plug easily. Heat can be very important in the winter.
jefro
I"ll suggest a proper generator disconnect. Back feeding a circuit breaker is usually quite dangerous unless the circuit is failsafe by mechanical means.
They actually make breakers designed to have ability to back feed. Not sure what the difference is.
FlasherZ
St. Louis Metro
The difference is an interlock which prevents that breaker from being on while the breaker supporting the grid is also closed.
But you'll need more than that - because the Lightning enforces ground fault protection on its receptacle, you'll need a transfer switch that isolates the home neutral and its bond, or you'll just keep tripping the truck's GFI.
adoublee
Midwest
2 EVs
Circuit breakers that are not labeled "line" and "load" are approved for bidirectional use. Some breakers, like those with a neutral sensing lead, have a directional element and may not be suitable.
PV2EV
There are number of 30A Manual Transfer Switch Kits available from $400 - $600 that will work. They are not that hard to install (i am in the process of doing it), or should not be to expensive to have installed. IMO this is the best (clean, safe, flexible, and affordable) value solution for the Lightning.
My concern is what is the power loss using the truck inverter, and what is the warranty on it?
