Can I drive the truck using just the passcode?
jredondox
Jorge
San Diego, CA
2021 F150
Can someone with paak active post ur vin? Maybe @Livnitup can help with forscan?
FlasherZ
St. Louis Metro
I'm stuck on 3.1.0 and learned yesterday I have the APIM downloaded and ready to install, but it won't. Tonight using Forscan I reset several modules, including the Gateway. A bit later when my app updated it told me I had an update waiting since August 8. So the truck knows it is there. It has now sent an update to the phone that is 21 days old, but if I go back to the truck now, there is no indication an update is available.
I would recommend you take it to the dealer and ask them to update it using FDRS, maybe it'll get you past whatever funk is holding your updates up.
My updates have worked fine - I'm on 3.4.0 - but no PAAK available to me (yet).
Slick68
22 Rapid Red Lightning, 68 Mustang, 17 Road Glide
For those with PAAK working: was your truck delivered with one FOB, or two?
Article linked above says Ford would deliver two FOBs with vehicles not PAAK enabled, and only 1 for those enabled. Mine came with 2, mo PAAK enabled.
Meanwhile, where in FordPass should this feature appear once enabled?
I received two FOBs
jredondox
Jorge
San Diego, CA
2021 F150
I got my truck on Friday. PAAK is 100% functional and I’m just using my iPhone to unlock, get in and drive away.
can you post your vin so we can get your as built data? or you can post as built data
jredondox
Jorge
San Diego, CA
2021 F150
I did a manual update but i didnt check the my key menu. Do you guys have this?
Ford F-150 Lightning Can I drive the truck using just the passcode? 436A4AFD-2753-44DE-A091-636AA195A675
jredondox
Jorge
San Diego, CA
2021 F150
Should have checked if this was there before
Ford F-150 Lightning Can I drive the truck using just the passcode? 052EFD26-0653-40E7-9345-CF23091D56ED
jredondox
Jorge
San Diego, CA
2021 F150
My key is different than Paak. It allows you to put limits on a specific fob
I know the difference I have a Mach e as well. Check the last shot I posted
jredondox
Jorge
San Diego, CA
2021 F150
Thank you for posting your vin. You got Paak working right?
Here are the 3 modules we can see involved with pask
Gwn and bcm we have the same software. And Paak values.
Your RFA Module software has a new version which is not even available on FDRS but I was able to get it with the help of an ice forum member. I did the update took an hour 🤦🏻‍♂️ but it’s done.
we think we have to wait for FordPass to recognize the new software so Paak can show on the app. It’s been 12 hours now…
Slick68
PAAK has worked (once I set it up) since I got the truck last Friday
FlasherZ
St. Louis Metro
Let me know when it appears on FDRS and I'll take the truck to the dealer to go get the push... :)
