Talk me out of a HIS by Sunrun
ExCivilian
'22 Platinum
So if you are using say 50% of your solar output, and the sun comes along an blocks 50% of the sun, your panels increase output so you are using all the available solar energy in the house.
This implies the IQ8s are capable of shedding excess power. Am I understanding you correctly that they are able to do that?
The current system that is being installed on my home doesn't have a battery in the plans. My installer texted me that in order to use the IQ8 grid forming tech I'd need to add the "empower smart switch, load controller, and critical load panel" for roughly $7,500. He followed that by saying the battery he was recommending wouldn't need any of it, which I believe was his earlier point of choosing a battery over the IQ8 grid-forming tech for the cost a few months ago during the design stage.
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
VTbuckeye
Vermont
In lots of Texas, basements are rare (houses are either sitting on Limestone, or in a swamp)
And in central Texas (or at least Austin) in particular, they have to be installed outdoors by code
In vermont everything freezes if it is not in the basement. There are some houses built with crawl spaces, but I have no idea how they keep the water lines and sewage lines from freezing when it is -20 degrees and the incoming water is maybe 38 degrees and the top foot of ground is frozen. Upon further thought the middle of the house plus copious insulation may offer enough protection, but basements around here make sense.
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
There are some other systems out there compatible with Enphase, Outback GD4048 and SMA sunny island that can also do this islanding. I have not looked into them all but I hear they work well. Perhaps that is what your installer initially referred to. I was looking from tech all from one company just for any warranty issues so no pointing fingers.
I think the generation shedding is done by simply turning off panels. For example, if you have a 16kW system with 40 panels it means you have 2.5% granular control of power generated. I assume you would see this real time in a maps of the individual microinverters. The smart switch is the system controller 2.
Here is what you need for sunlight backup. The IQ load controllers can be replace with a Lumin panel and do whole home backup and just pick the loads you want up to 16 circuits. Enphase has a 16 circuit upgrade coming early next year. Of course adding one small battery expandable with an EV battery at some point gives more flexibility while you drive to get a fast charge. The nice thing is with the system controller 2, a Distributed Energy Resourced (DER)/MID panel, you can add solar, batter, generator to the supplied inputs at any later time. All the power sources are additive, not either/or, a unique feature of the system since either the batter or the PV can form a grid and match phase and frequency to the utility grid or a attached generator. The only thing you can't do is run a generator and utility at same time ;)
Ford F-150 Lightning Talk me out of a HIS by Sunrun 1663027706145
Ford F-150 Lightning Talk me out of a HIS by Sunrun 1663027755023
ExCivilian
'22 Platinum
His position is that installing all of the equipment necessary for the IQ8 grid-forming feature is an unnecessary expense compared to installing a battery that can power the house during inclement weather and darkness.
Ford F-150 Lightning Talk me out of a HIS by Sunrun Screen Shot 2022-09-12 at 5.29.07 PM
PiMatrix
Phil
New York
F-150 Lightning
Electrical Engineer
Don't know on the prices, but I agree that having 24 hour coverage is better than only sunlight hours with no battery. That's why I'll have a small Enphase battery for day time to handle clouds, and the EV additional capacity for overnight while it's in garage or extended outages. There are many many ways to accomplish the same thing. Devil is in the detail.
smax64
New york
09 F250 FX4
Firefighter
Finally got info back from the town of eastern long island and here is the issue for the HIS in NY at least
Ford F-150 Lightning Talk me out of a HIS by Sunrun 1663597640909
NY so far does not have a provision in their electrical code to allow for ER battery
adoublee
Midwest
2 EVs
Your Ford F150 lightning is an energy storage system, and is apparently banned where you live. Welcome to America.
smax64
New york
09 F250 FX4
Firefighter
only to put power back into the house, i can still charge it
That’s really funny…..if you have an LP backup generator, having 5 gallons of propane on your property to run it violates those numbers. ?
Firestop
Firestop
Curious, what hazardous condition are they attempting to prevent……?
tls
New York
2022 Lightning
I believe they are misreading the code. Or, actually, almost deceptively quoting it. Here is the preamble to R327, which exempts vehicles from 327.2 thru 327.11.
[NY]R327.1General.​
Energy storage systems installed in buildings or structures that are subject to the provisions of this code shall be installed and maintained in accordance with Sections R327.2 through R327.11. The temporary use of an owner’s or occupant's electric powered vehicle as an energy storage system shall be in accordance with Section R327.12.​
