mrcoolgli
Let me know.. I hope it's just a bug.After I posted my screenshot from the app I was worried that might be the case.
I have an Emporia Vue so I will try the same test in a few hours when I am up.
@4ReeleyI manually set the dial to 48A in the FCSP but the app still shows the full scale up to 80A. It would be more clear if the app received feedback from the FCSP and adjusted the scale appropriately. I set the app to 48A to match the dial in the unit but Iām not sure if that actually makes any difference.
I measured withnclamp meterMine is a little more specific. What I mean by that.. is I ran 2 gauge wire and installed a 100amp breaker. so my physical switch setting is on 7 = 80amps. This part works and I can confirm using my home energy monitoring system sense.com that the number of kW being consumed equals out to around 82amps.
When I go into my FordPass App and adjust the rate down to anything below 80. I've tried 50,40,30,15,6. The kW being used according to my monitoring system do not go down at all.
I have a wallbox charger as well and it supports turning down the AMP's. I can clearly watch the kW drop on my sense.com monitor.
So what I am saying it's not guess work. It's actual data showing it's not dropping. I am curious if anyone else has similar tools to validate if it's working as expected or are most people just trusting the app that it adjusted down. I hope this makes sense.
So if you turn yours down in the Ford Pass App does the AMP draw go down? Mine does not.I measured withnclamp meter
Exactly. Those readings are for 48 amp and 80 amp settings. Iāll concede some error in the clamp meter but not much. Maybe a few % of reading.So if you turn yours down in the Ford Pass App does the AMP draw go down? Mine does not.
I apologize.. I didn't see the second photo of it showing the lower amperage.. Ok.. well maybe there is something wrong with mine...Exactly. Those readings are for 48 amp and 80 amp settings. Iāll concede some error in the clamp meter but not much. Maybe a few % of reading.
I haven't received mine yet, but I plan on wiring it for 80 amps and probably only having it set to 64 amps in winter and 48 in summer. I'll need to recover more mileage in the winter and less in the summer during my off-peak charging times.If youāre wired for 80 A what is the advantage of dialing the charging rate down? Does this somehow help with battery longevity?
Outside of preconditioning during the winter I see no advantage. I wonder about small draws when set to 80Ć causing excessive cycling.If youāre wired for 80 A what is the advantage of dialing the charging rate down? Does this somehow help with battery longevity?
