BennyTheBeaver
Looks great to me!Our design on the lightning mud flaps.
We are making 3d sample and will test them out soon.
whats your thought?
whats your thought?
ConsoleVault is the actual OEM for the Ford branded vault. While I ordered mine directly from them, it's the same vault. Even has the Ford logo.oh, all of our current test are using the OEM vault, not sure if that will fit in these type of lock. thank you very much for sharing, I will definitely bring this to the team
It doesn’t look like they are long enough down to be effective.Our design on the lightning mud flaps.
whats your thought?
Let me know when I can buy a pair, don't care if I have to beta test them first.Our design on the lightning mud flaps.
whats your thought?
Looks great. Throw them in the same box with the console safe tray and I'll throw them on.Our design on the lightning mud flaps.
whats your thought?
Any chance of adding the Lightning logo to them?Our design on the lightning mud flaps.
whats your thought?
I'd prefer the clean look, probably more universally appealing that way.Any chance of adding the Lightning logo to them?
Why not both!I'd prefer the clean look, probably more universally appealing that way.
mayMy ConsoleVault finally arrived, and I too am interested in the small tray. It's worth mentioning that there are different locks for the vault, and they have slightly different profiles. The area in the center around the lock should be open enough to accommodate all 3 lock types (key, combo, and elite combo).
In case you haven't seen it, here's the link to the vault itself, and this page has links to the different lock options.
https://www.consolevault.com/Ford-F150-Full-Floor-Console-2021-2023_p_224.html
thank you so much for this info, may i know which lock options did you go with? we could probably send you a 3d sample and lets see if the current design fit before we make the molding?ConsoleVault is the actual OEM for the Ford branded vault. While I ordered mine directly from them, it's the same vault. Even has the Ford logo.
we did discuss about this, but we have a trademark legal concern here. we also thinking adding the pattern on the front grilleAny chance of adding the Lightning logo to them?
No, range is a big concern. That's a good start.we made it smaller compare to our ICE F150 mud flaps, because some Owners might concern about the range.
Shall we make them bigger?
I went with their Elite combo lockthank you so much for this info, may i know which lock options did you go with? we could probably send you a 3d sample and lets see if the current design fit before we make the molding?
Maybe make two versions? I’m less concerned about range and would rather the flaps protect the truck.we made it smaller compare to our ICE F150 mud flaps, because some Owners might concern about the range.
oh no, we are only gonna make one version, as these molding are pretty costly.Maybe make two versions? I’m less concerned about range and would rather the flaps protect the truck.
