Tire size options for OEM wheels with 2" level?
mnsunset
Kurt
2015 F150/1965 Mustang
Self Employed
Saw someone mention terra grapplers....anyone run them? I have them on my current truck. Great in the snow BUT no traction on dry pavement....And if you give her a little gas while crossing a painted crosswalk or similar,,,,forget it. Spins like your on ice. Overall I really do not like the tire other than the way they look. I am leaving them on the truck when I trade it. (I have two sets of tires wheels that I rotate. Summer and winter).
Kurtis
Arkansas
21 F-150 Platinum
Madman
Kevin
Boston, MA
3 Ford Explorers
I currently run KO2 and love them. Out of curiosity, why not get a load range e?
I am planning to get KO2’s for my Platinum FX4 as well. I had them in the past on an SUV and they were great in the snow in ski country.
The biggest I can fit (after the 2” level) without any poke seem to be the 285/65/R20’s, at 34.5” Radius.
The only problem is that the stock height of the cab plus the level plus taller tires comes almost exactly to the height of my garage door arm bracket. And that doesn’t include whatever height the FX4 kit may have added!
(77.2 + 2.0 + 0.75 + [FX4 h] = 80.0+)
On second thought, it’s not a problem. I’ll just do surgery on the door arm brackets or replace both garage doors!
Problem solved! ?
05RubiconLJ
Matt
Arkansas
'05 Rubicon LJ, '21 F-150 Platinum Powerboost
Added pictures to my original comment. Not sure if that notified you or not.
It's gorgeous! Now that my truck is built, seeing your truck out on the streets makes the wait for delivery all the more arduous.
Problem solved! ?
I have the same issue. I want the truck leveled and bigger tires, but what is going to be the impact on my ability to get it into the garage. Parking it in the driveway, no matter how much I love the look will be strictly forbidden.
Ford F-150 Lightning Tire size options for OEM wheels with 2" level? 622C21F1-E651-4813-80FC-E410F3BB28C4
Asphaltman
Salt Lake City
2021 F150 (produced 2/11) 2018 F-150 1997 F-250HD
Entrepreneur
Problem solved! ?
Do you think the 285 65/20 will work with a 9” wheel?
C_Low
Cody
2021 F-150 Lariat Sport
Just had the 2 inch Ready Lift level with 285/65 Ridge Grapplers on the 20 inch OEM wheels installed yesterday. Will post some pictures today for you when I can. I like the height of the 285/65 @ 34.80 inches tall in Ridge Grapplers. Definitely looks to have a little more sidewall vs the 295/60 but both look great.
Pictures added. As many have others said, no rubbing and no trimming.
Looks awesome! Thanks for sharing. So even at full lock you don’t rub the UCA going forward or in reverse?
Madman
Kevin
Boston, MA
3 Ford Explorers
Toyo Open Country AT3 275/65 and level
Well done! This might be the best Level/Tire pic I've seen on this Forum. Fantastic. I am definitely inspired to do this (if I ever get my truck!)
Madman
Kevin
Boston, MA
3 Ford Explorers
150ish
Scott
2021 Ford F150
Inspector Gadget
Problem solved! ?
Those aren't real world measurements. The highest point on your cab wont increase by the exact amount as the front end. The pivot point is going to be rear axle. I try and find people on here doing what I want to do to my truck and get real numbers from them. I'm pretty sure what your describing will fit in the garage.
150ish
Scott
2021 Ford F150
Inspector Gadget
