AR2021Platinum
Star WhiteWhat color is your platinum? Will be very helpful to see your pictures when you get a chance!
Added pictures to my original comment. Not sure if that notified you or not.What color is your platinum? Will be very helpful to see your pictures when you get a chance!
Got it. Truck looks awesome!Added pictures to my original comment. Not sure if that notified you or not.
I am planning to get KO2’s for my Platinum FX4 as well. I had them in the past on an SUV and they were great in the snow in ski country.I currently run KO2 and love them. Out of curiosity, why not get a load range e?
It's gorgeous! Now that my truck is built, seeing your truck out on the streets makes the wait for delivery all the more arduous.Added pictures to my original comment. Not sure if that notified you or not.
I have the same issue. I want the truck leveled and bigger tires, but what is going to be the impact on my ability to get it into the garage. Parking it in the driveway, no matter how much I love the look will be strictly forbidden.I am planning to get KO2’s for my Platinum FX4 as well. I had them in the past on an SUV and they were great in the snow in ski country.
The biggest I can fit (after the 2” level) without any poke seem to be the 285/65/R20’s, at 34.5” Radius.
The only problem is that the stock height of the cab plus the level plus taller tires comes almost exactly to the height of my garage door arm bracket. And that doesn’t include whatever height the FX4 kit may have added!
(77.2 + 2.0 + 0.75 + [FX4 h] = 80.0+)
On second thought, it’s not a problem. I’ll just do surgery on the door arm brackets or replace both garage doors!
Problem solved! ?
Do you think the 285 65/20 will work with a 9” wheel?I am planning to get KO2’s for my Platinum FX4 as well. I had them in the past on an SUV and they were great in the snow in ski country.
Problem solved! ?
Looks awesome! Thanks for sharing. So even at full lock you don’t rub the UCA going forward or in reverse?Just had the 2 inch Ready Lift level with 285/65 Ridge Grapplers on the 20 inch OEM wheels installed yesterday. Will post some pictures today for you when I can. I like the height of the 285/65 @ 34.80 inches tall in Ridge Grapplers. Definitely looks to have a little more sidewall vs the 295/60 but both look great.
Pictures added. As many have others said, no rubbing and no trimming.
Looks really good. Do you have any more pictures of it? Different angles?Toyo Open Country AT3 275/65 and level
Well done! This might be the best Level/Tire pic I've seen on this Forum. Fantastic. I am definitely inspired to do this (if I ever get my truck!)Toyo Open Country AT3 275/65 and level
Check this one out:Do you think the 285 65/20 will work with a 9” wheel?
@Asphaltman -Do you think the 285 65/20 will work with a 9” wheel?
Those aren't real world measurements. The highest point on your cab wont increase by the exact amount as the front end. The pivot point is going to be rear axle. I try and find people on here doing what I want to do to my truck and get real numbers from them. I'm pretty sure what your describing will fit in the garage.I am planning to get KO2’s for my Platinum FX4 as well. I had them in the past on an SUV and they were great in the snow in ski country.
Problem solved! ?
What spacer kit are you running?Toyo Open Country AT3 275/65 and level
