Can you provide the details around the parts/components/brand?Keep in mind this is a 3 inch level! It’s not a spacer lift it’s upper control arms
Sure! Here’s a linkCan you provide the details around the parts/components/brand?
Thanks so much. Have you noticed any impact on wind noise?
I do have the Max Trailer Tow package, yes, and I have also heard that is a factor.Im thinking of doing this setup since my son has a 23 Raptor....test fitted and it def hit the tapered end with my calipers. I was torn between a 1/4 and 1/2" spacer so this might push me to go with the half. Curious if you have the max trailer package or if that will make it not able to fit as well...either way I have them here to test so figure why not.
