Leveled on 315/75r17s
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
Wastewater Collections Technician
Keep in mind this is a 3 inch level! It’s not a spacer lift it’s upper control arms
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
Thanks so much. Have you noticed any impact on wind noise?
Not at all! A bit of tire noise if the radio isn’t on though
Craiguf
Craig
Utah
2022 F150 Lightning
Nice setup. Is the range still holding? 10% less? I’m wanting to do the same to my platinum
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
Range still holding. 90% charge shows 202 miles. Dash says I’m getting 2.0-2.1 mi/kw
Craiguf
Craig
Utah
2022 F150 Lightning
Any issues with weight of the lightning vs weight of a raptor? Can the wheels/tires hold it safely?
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
The tires are better rated for load than the stocks. I have a hard time finding the technical specs of the wheels but they are plenty for the lightning.
Ajjra
New York
F-150 Lightning Lariat
Probably a slim chance, but figured I’d ask - did you happen to weigh the wheel and tire before mounting it to your truck?
Jml91
Jml91
Johnny
San Diego
2023 Ford Lightning
Didn’t need to! It’s 92 pounds per wheel and tire per the specs
jmb01
Oklahoma
2022 Iced Blue Lariat ER
I found a cheap set of Gen1 SVT wheels, snagged them for a similar set up and they just touch the caliper with .5 spacer :rolleyes: I'm guessing there's just the slightest of differences in the wheels from the ones you found to the gen1. It literally looked like a mm or 2...
bmw325_num99
Jordan
Chicago, IL
2022 Lightning Lariat ER, 2018 Tesla Model 3
Hello @Jml91 . Any chance you could tell me how high this truck is from ground to the top of the roof antennas? I am worried about this same setup clearing my garage.
Shodan01
Steve
2023 Platinum
Im thinking of doing this setup since my son has a 23 Raptor....test fitted and it def hit the tapered end with my calipers. I was torn between a 1/4 and 1/2" spacer so this might push me to go with the half. Curious if you have the max trailer package or if that will make it not able to fit as well...either way I have them here to test so figure why not.
bmw325_num99
Jordan
Chicago, IL
I do have the Max Trailer Tow package, yes, and I have also heard that is a factor.
FYI, once I saw the weight limit specs for ICE F150 wheels vs Lightning f150 wheels, I decided to stick with Lightning-specific wheels because otherwise that inferior spec would be on my mind especially if ever towing/hauling/offroading
