BennyTheBeaver
Thanks, Just ordered Patina Red
That will match your Red Truck nice! The seller is also really responsive if you have special requests (like I requested Black hardware instead of the standard silver).
For what it's worth, I did pay for my order, I'm only raving about it because it is high quality and surprised me with how nice it is.
laselvasurf
Phil
Santa Cruz CA
Got Forscan and installed bed lights plus enabled the matrix headlights on my XLT SR.
Any tips you can offer or is it as simple as it looks? I just got the bed lights and plan on enabling the matrix headlights while I'm in Forscan.
Also, out of curiosity, does your XLT have zone lighting and if so, do the bed lights show up in that menu?
laselvasurf
Phil
Santa Cruz CA
If I may ask, what is your use case? The only thing I could think of is securing a firearm and I don't carry.
Another use case is keeping a key inside the safe. I run/bike/swim often and don't like keeping my key on me. When I leave the truck I'll sometimes put the key in a faraday bag in the safe and then lock/unlock through the keypad. I also keep my wallet and any other valuables in there when I'm out away from the truck.
I've done this for years with my raptor and it's very convenient not having to worry about loosing or damaging a key.
SkyeFox
Steven
NJ
Nissan Leaf, F150 Lightning XLT SR on order
The bed lighting was simple. You pop out the covers, set up the wiring and lights, and make 3 changes in Forscan. I have zone lighting and they come on with the rear zone or you can turn them on manually in the bed.
The matrix lights are easy to enable just a bit time consuming.
Making these changes in Forscan did impact some of my settings in the truck so you may have to redo a few settings but it's not a big deal.
256fail
Alabama
23 F150 311A XLT
Pilot
My dealer was nice enough to swap over my new tonneau cover from my f150 trade.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? 1288C2D5-1BFD-4EB0-9CD4-524D045BA25A
BennyTheBeaver
Coolbreeze704
Troutman NC
Ordered my faux Stacks for the bed. :p
Lol, I was thinking of channeling music through them but bubbles are by far the better option.
Also think of the confused or pissed off looks that would get when taking up a charge point space.
LUXMAN
F150 Lightning PRO and XLT
Pilot
Added Ford BoxLink to my Pro.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? D398FFD1-8523-47FE-95FA-DE1681A2C79E
HaroldCal
Harold
Las Vegas
How was the fit with your bed liner? I had heard about others having fitment issues after a spray in bed liner, and sure enough, I found I had the same. I've seen various suggestions to resolve it. What did you end up doing?
LUXMAN
Pilot
This was a dealer installed bed liner.
It was somewhat in the holes for the boxlink. But really, all I did was use a round Torx screwdriver T-27 (actual screwdriver and not the bit on a driver), found it was the right size and just ran it though each hole to clear it out.
THen used some spray silicone on the bolts and used a T-30 to drive them in a bit by hand, then used an impact to drive it home. It was not a problem.
HaroldCal
Harold
Las Vegas
I was referring to the cleats.
LUXMAN
Pilot
No issue. Slid right in and up. Locked right in. I have a very thick bedliner. Thicker than most and it isn’t an issue.
my wife’s XLT has the premium LineX liner and it isn’t an issue there either.
These are the Ford OEM plates and cleats. I know some people buy the China knock offs off Amazon, which I understand, but that may be their issue…. 🤷‍♂️
