Awesome, thanks!Same as the 2021 and 2022 ICE trucks. You can look them up and compare on Cruchfield.
https://www.crutchfield.com/car/outfitmycar/mycar.aspx
I ordered the speakers you mentioned in your other post and the wiring adapters/harnesses. Did you have to get any spacer rings or other adapters to attach the Infinity speakers or will they just bolt right up?I can help a little further, as Crutchfield didnt have experience with the Lightning when I asked them.
The Pro/XLT's have 6.5" for the front and rear. The front can have 6x9's but you need an adapter for the speaker. They also have two tweeters up front.
The 6.5" for the rear bolt right in. I bought some baffles for them to sit in, poor man's anti-rattle.I ordered the speakers you mentioned in your other post and the wiring adapters/harnesses. Did you have to get any spacer rings or other adapters to attach the Infinity speakers or will they just bolt right up?
Thank you for the info! Have you replaced your front speakers as well? I ordered 4x of the infinity speakers as I figured having a matching set wouldn't be a bad thing.The 6.5" for the rear bolt right in. I bought some baffles for them to sit in, poor man's anti-rattle.
I have not yet, next audio install is the 10" JL sub I bought. The Infinity's highs and mids are really clear, the bass will need some tuning if you aren't also installing a sub. The clarity in the high/mid is like night and day compared to the paper cones.Thank you for the info! Have you replaced your front speakers as well? I ordered 4x of the infinity speakers as I figured having a matching set wouldn't be a bad thing.
Awesome, thank you! I may get a subwoofer as well down the road. Do you have a link to the baffles you used in your rear doors?I have not yet, next audio install is the 10" JL sub I bought. The Infinity's highs and mids are really clear, the bass will need some tuning if you aren't also installing a sub. The clarity in the high/mid is like night and day compared to the paper cones.
https://a.co/d/30Y8HY1Awesome, thank you! I may get a subwoofer as well down the road. Do you have a link to the baffles you used in your rear doors?
No, the front is an awkward size, you will need some brackets to make the 6x9's fit...may need some modification.So can I just drop the Infinity’s right in both front and rear?
Same question and can someone link those infinity speakers? How hard are they to install?So can I just drop the Infinity’s right in both front and rear?
It looks like I need the Metra 82-5607 speaker bracket adapter in order to install a standard 6.5" speaker in the front doors.No, the front is an awkward size, you will need some brackets to make the 6x9's fit...may need some modification.
I'm a little confused here, did you mean to say 6x9 for the front?No, the front is an awkward size, you will need some brackets to make the 6x9's fit...may need some modification.
