msadan
- First Name
- Dan
- Nov 29, 2022
- Lafayette IN
- 2023 F-150 Lightning Pro
Charging at home using a 48A Wallbox, the Wallbox app shows the truck (Pro with the standard battery) charging at 10.5 kW. Same thing charging at a Tesla destination charger (using an adapter of course). Seems like I should be seeing 11.5 kW (240 V, 48 A). I've used the Wallbox with my Tesla, where it will display the actual current and voltage, and it typically charges at the rated 11.5 kW (generally between 238-240 V, 48 A).
This really isn't a problem since I'm never in a hurry when charging at home. I guess I'm just curious if others are seeing the same thing.
