PV2EV
Well I started to drill through my ICF wall, having guessed where the rebar is, and of course hit cross of rebar, making a mess out of the hole. Although the bit can cut through it, I don't want to. I will continue when it cools off later in the week.Adding some pics. First, the hole through the stucco. Like I said, I knowingly destroyed a (non-masonry) hole saw to do this. I still had to file the hole a bit afterwards. Next two pics are of the closed & open pass-through. Last is from the inside of my unfinished garage. Also, for the RV part listed in my previous post, I had to shave (I used a dremel) the plastic cable grips so that the Tesla HPWC could fit through.
