FCSP - Mounted Indoors with Cord Under Garage Door
PV2EV
Adding some pics. First, the hole through the stucco. Like I said, I knowingly destroyed a (non-masonry) hole saw to do this. I still had to file the hole a bit afterwards. Next two pics are of the closed & open pass-through. Last is from the inside of my unfinished garage. Also, for the RV part listed in my previous post, I had to shave (I used a dremel) the plastic cable grips so that the Tesla HPWC could fit through.
Well I started to drill through my ICF wall, having guessed where the rebar is, and of course hit cross of rebar, making a mess out of the hole. Although the bit can cut through it, I don't want to. I will continue when it cools off later in the week.
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door PXL_20220807_040214003
PV2EV
I did complete (minnus one clamp) the external install on my vacation house. run with 100amp wiring for future upgrade.
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door PXL_20220814_220054612
Tingleyfeeling
Brent
Ford F 150 Lightning 2022
Maintenance
I mounted my Autel charger in the garage but my truck is 4 inches to long to fit in my garage. I didn't want to put the cord under the garage door so I made this pass through. It is very easy to store my connector in the garage and put it through the door. I used a door I bought off Amazon that locks. I am very happy with the results.
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door 20230214_150142
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door 20230214_150332
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door 20230214_150407
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door 20230214_150426
Very nice, clean looking installation.
Whats the copper-looking thing bolted to a stud? Just curious.
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
I want to do a similar setup. Can you post the link to the Amazon page? Thanks
luebri
Neenah, WI
That appears to be part of the locking mechanism
You’re right…I never thought that the lock would be inside, but it makes sense. No key required that way!
Thanks
Tingleyfeeling
Brent
Maintenance
Yes, it is the lock for the door. I hang the key just inside the garage.
Tingleyfeeling
Brent
Maintenance
Tingleyfeeling
Brent
Maintenance
I cut a piece of pipe foam insulation around the cord so I can fill in the gap when the cord is put through. Keeps the cold out in the winter and the bees out in the summer.
Lytning
Georgia
Here is my approach for those who have basic wood working skills. The board is full width of the door. It fits inside the door track on each end to keep it in place.
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door Cable Guard 1
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door Cable Guard 2
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door Cable Guard 3
Ford F-150 Lightning FCSP - Mounted Indoors with Cord Under Garage Door Cable Guard 4
brewski
GA
2023 F150L Platinum
Yes
I'm keeping my Model S and I have a gen 2 Tesla HPWC in my garage, and will use that to charge both vehicles--using a TeslaTap for the F150L. F150L won't fit in my garage and my garage door won't close on the HPWC cable.
I already punched a hole through the side of my garage (stucco) with a hole saw and cordless drill (on the hammer setting and I knowlingly destroyed the hole saw, I couldn't find a masonry-specific version). I seated an RV cable pass-through in the hole, and set it with stucco RTV sealant.
I'll try to remember to report back here with pics in the nex day or two (I'm at work). Here's the pass-through I set in the hole....
https://www.amazon.com/dp/B07JFGMY6N?psc=1&ref=ppx_yo2ov_dt_b_product_details
Our Tesla charger is in the perfectly wrong place, except for a Tesla.
I have to pull my truck in half way to charge on it.
A second charger will be going in fairly soon.
hihosilver
Len
New Jersey
2022 Lightning Lariat - SR - Oxford White - MaxTow
Now show them the top of your garage door when closed.
