Strangatang
Dan
NJ
2022 Ford Lightning
Just did mine... Dropped the rear about 3 inches. It's about all you can do before having serious camber issues. Rides great though!
Can't wait for someone to come out with a proper drop kit for it... I want it lower!
How did you lower the rear? And what’s the specs on the vossens?
CRAIGC540
Craig
Moreno valley
Technician
Looks perfect just like I want mine. I'll wait for the kit though.
jasonator
Jason
Tampa
2022 F150 Lightning
Can you share the part numbers and process? Was this the shock that had to be cut and welded back together or plug and play?
Did you do the work or a shop?
Does it require an alignment afterwards?
Inquiring minds have to know!
ScubaSteve
Steve
Missouri
2022 Lightning Platinum, 2021 GT500, 2017 Focus RS
Sales
Can you share the part numbers and process? Was this the shock that had to be cut and welded back together or plug and play? Belltech 25001 bolts right up to the rear. Adjustable height, no cutting/welding.
Did you do the work or a shop? My Dealership did it.
Does it require an alignment afterwards? Yes you will want to check alignment.
F150ROD
F150ROD
U.S. Navy Retired
so what does the kit look like? What is the drop? Cost estimates?
any details are appreciated.
Who knows since these just got done and are still prototypes. Pretty much we are still in the R&D phase but getting closer. You can probably look at the ICE equivalent and get an idea of cost/drop and reviews.
The front leveling kit I am running has been outstanding, it truly does feel just like stock, although there is still a bit of rake and efficiency has dropped slightly. But the bounciness from the stock suspension is gone. I am curious to see what the lowering kit will do.
bryko
bryko
Alabama
'23 Lightning, '22 Corolla, '13 Escape
I’d like an option for the rear only being lowered. Whatever is level, I’m guessing 2-3”.
I probably would want mine to look like the F-150 Lightnings on the Ford website Build and Price illustrations which appear perfectly level with the rear lowered. Or raise the front about 2.5" and put Nitto Ridge Grapplers on my stock Lariat wheels.
F150ROD
F150ROD
U.S. Navy Retired
Come on, stop teasing
🤣 I’m sure they’ll be posting pics soon, I too want to see it lowered although I opted for the lift. So far the feedback from them is that the lift rides and handles amazing. They should be putting on the lowering springs today.
Strangatang
Dan
NJ
2022 Ford Lightning
That’s so excited. I’m def interested in the lowering options.
F150ROD
F150ROD
U.S. Navy Retired
Lowered on Eibach Springs with Stock Shocks, I took a screenshot of Lightning specific content from Eibach’s Instagram
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 090E9F77-2CE8-4FA9-9357-BCD163E682F2
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input D11406EB-C26B-4823-B1A5-9BF3142D9496
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input AAED1EEA-846E-4A86-883D-BAEFDF766596
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 056F6420-DE3A-498C-9D05-861FBDE9B6E6
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 1DCA5931-624C-4B0F-B0A3-C4A20B14FBD5
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 78897D4A-6B6F-41AD-AD3B-1F22728DA896
