KemperC
New 2023 Lariat ER and have tried two different home chargers, both under my expectation. 1) Ford mobile plugged into dedicated 50AMP plug (NEMA 14-50) Ford Pass showed 6kW. Calculated from LOG data was really 6.6kW. Expected 7.2kW so was 9% under. 2) Grizzle smart charger plugged into same 50AMP plug. FP showed 8kW rate. Calculated from log data actual was 8.2 kW (14% under). Talked to Grizzle tech support and confirmed their settings and that we should see 9.6kW. This makes me feel like the TRUCK is not achieving max rate.
Has anyone else looked at their home charge rate- what are you getting?
Thanks.
Thanks.
