Number of modules in the battery pack
jmc6020
New Hampshire
2023 F-150 Lightning Lariat
Does anybody know how many modules make up the battery pack of an extended range lightning? I know for a fact there are nine modules in the standard range
Gimme_my_MME
9 modules in both, the modules just contain different number of cells depending on SR vs ER
jmc6020
jmc6020
New Hampshire
Thanks for the info. I was looking inside my battery pack with a service tech yesterday and he said I had an extended range because there were nine modules. I have a standard range so I was wondering if Ford was limiting with software or if the capacity of the modules were actually different
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Fewer cells in the same size modules? From the Munro tear down I don't understand how that is possible? Can you help me understand?
eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
They are certainly different packs with substantially different weights. They are not using software to limit your range.
GoodSam
Good
occupying space
Just to update this thread, we know now that the number of modules for a SR, standard range, is only 6; the ER has 9.
Sorry, i am wrong, SR has 9 small modules, ER has 1 small and 8 large; both have 96 "cells", however the each "cell" is made up of parallel cell pouches. The SR has 4 cell pouches in parallel, while the ER uses 5 cell pouches in parallel.
see this September, 2024 thread on counting up the cells in the modules:
estimating-the-number-of-pouch-cells-in-battery-modules-a-conversation-with-\chatgp
