YouTube Streaming Decoder Artifacts
Levi8than
Joe
2023 f150 lightning lariat
Electrics Engineer
Curious if others have seen this issue. If yes, then it's likely systemic or a software issue. If no, then I guess I should schedule a date with my local dealership.
My streaming free-pass is about to expire, and I believe I lose the ability to stream even over my own WiFi when that happens, but even so, I'd like to know the hardware isn't faulty.
See the green lines on the right side of the screen when displaying the video? These sort of jump around during playback. Doesn't much matter what video I choose to watch. Have other experienced this?
Ford F-150 Lightning YouTube Streaming Decoder Artifacts 1687910344309
Amps
Bolt
I haven’t experienced the artifacts.
I haven’t used my Ford Streaming trial. You can stream on home Wi-Fi and, supposedly, open public Wi-Fi. If there’s a way to use an iPhone as a hotspot via Wi-Fi, I haven’t figured it out yet. I hope there’s a way to do that.
I used mine yesterday morning while charging at EA, worked perfectly the hour that I was there.
I'm now on the paid streaming plan at $10 a month.
CRAIGC540
Craig
Moreno valley
Technician
Yes I have seen that before on many devices, its usually from low streaming speeds and the software is adjusting to a lower bit rate. I bought a iPhone for my wife and it came with a free iPad with $10 a month data service from Verizon. I keep it in the truck to use as a hot spot and it works great,
Levi8than
Joe
Electrics Engineer
Yes I have seen that before on many devices...
I appreciate the response, but I disagree. If that were the case, I'd see resolution issues and color-banding across the entire screen. I'm not seeing that, this is only on the right side and it's always green, no matter how good the connection is. From the responses, it sounds like others do not have this issue, and I likely have a faulty part.
In to see the service folks, I shall go.
CRAIGC540
Craig
Moreno valley
Technician
Yes if it's in the same spot then it's a screen issue.
