Traconesu
- First Name
- Patrick
- Aug 23, 2022
- Quad cities, Illinois
- Ford lightning platinum
- Occupation
- Retired
I believe it does mine. I seldom have to touch the brake because the vehicle uses all the braking more efficiently to put the energy back into your battery. Here's a simple test. Drive as you would normally without one pedal driving, coming up to a stop sign. Once you come to a complete stop you'll see your regenerative braking score. Now turn on one pedal driving and repeat that procedure without using your brake pedal. Note you may need to let up on the accelerator a bit sooner than you did when you were using your brake pedal. Also turn on what's called vehicle hold which will keep your vehicle from creeping while at a stop sign when your foot is off the accelerator. Your braking efficiency should have gone to 100% as long as you don't use the brake pedal.I don’t think so!? Will it improve my range?
