Streaming kits _ (Magic Box)
CallaDrilling
Dan
Berlin, NJ
2022 Ford Lightning Lariat
WellDriller
anybody have any luck with the MAGICBOX style streaming kit sold on Amazon?
I tried 2 different ones so far with no luck. I am having trouble getting the HULU app ( netflix, disney+, youtube all work) to accept my log in information on both kits, even after triple checking the information is accurate on other devices.
If you have a working device, let me know which one is working for you.
roddiaz1
Rod
Pittsburgh
That does look rather interesting.
Would be a huge upgrade to the ”Entertainment” options available on the Sync 4 to date.
Keep us updated if manage to get this to work.
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
I've had good luck with the CarLink adapters. I think the secret is you need to subscribe to the ATT hotspot and connect the Carlink adapter to that wifi source. It streams any of the video apps I have loaded. I primarily use it to stream Sirius XM since the satellite version doesn't work here. (I just keep my phone in my pocket.)
stickyfingers
Sam
Toronto
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I've used CarLinKit for over a year now and it's perfect. The ATT hot spot from the truck is an absolute must as someone said earlier. It has better mobile antennas than anything available/usable as a data connection for magic box devices, including internal. My kids wouldn't even know what to do if they couldn't watch Disney+ and Netflix.
LSUT1GER
Slidell, LA
Computer Engineer
I just got the MAGICBOX 2.0 for my F150 Lightning Lariat. Does your MAGICBOX display over the whole screen in your Lightning Lariat?
LSUT1GER
Slidell, LA
Computer Engineer
And do you still have it and are using it?
CallaDrilling
Dan
Berlin, NJ
WellDriller
Yes I still have the kit installed. I have not used it since it was installed, because the Hulu app did not allow me to log in. No matter how many times I've confirmed my information.
About 2 weeks ago I tried again and it worked!
The screen size does not use 100% of the available space. But it is a full sized image without any distortion
CallaDrilling
Dan
Berlin, NJ
WellDriller
