What are some upgrades or Add-on done for the F-150 Lightning
Gunnerbill
Las Vegas
F150 2022 Lightning Platinum Plus
I am interested in what upgrades folks have done with their "LIGHTNING". I have added a few things. I use my lightning as a daily work vehicle so purchased some decent seat cover from Amazon. And used also as a personal vehicle.
List of stuff I gotten:
  • ARE camper shell (A.R.E. Model: Z2)
  • Tinted 20% Ceramic Windows (Im in Las Vegas)
  • Truck Line-X Premium Bed Spray Protection
  • Train horns (Hornblaster's Train Custom Insane Conductor Version, it Has (x20) Horns) Insanely Loud!!!
  • Ford Front LED Ford Emblem (Putco Brand)
  • Amazon Special Seat Covers
  • Husky weatherbeater floor mats set and bed liner mat
  • Center Console organizer
  • Decals and raised lettering
  • Adjusted the center console spring so it would stay up and not fall on my arm any more.
  • Rydonair Antenna Compatible with Ford F-150 2009-2023 / 13inches
  • Ford OEM Mud Flaps (For the F-150 Lightning)
The next upgrade think of:
  • Also going to make a Aux Battery disconnect switch. Though it hasn't been required to do yet, quite a bit of discussion lately on the necessity to disconnect the 12v battery to reboot the system and restore connectivity. It is a pain to to dig out a 10mm wrench if needed.https://smile.amazon.com/gp/product/B07JZ9NDH2/
  • Want to do some kind of interior emotive lighting. The older F150 (2016-2018) had cool lighting in there cup holders, mine doesn't have it and it look dull....
As for my Air Horns, They are super cool and "VERY" loud. They are not meant for going cruising around a scaring people or going by golf courses and messing with golfer, but I do let the idiot drivers know that they f*@ked up. Of course they let me know I'm #1 by flipping me the bird
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145357
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145435
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145511
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145526
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145605
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230129_145650
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230205_154920
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230205_154929
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning Train Horn on side
invertedspear
AZ, USA
lightningcalcs.pages.dev
Are there instructions for this? I didn't realize I wanted to do it till you told me you did it. That thing is annoying at how easily it falls.
ctuan13
Chuck
Pittsburgh, PA
My mods:
- pedestrian warning bell and a momentary switch in the footwell
- removed the trunk beeper
- Ford mudflaps
- Retrofitted factory deleted ambient lighting and glove box light
- disconnected TCU
- cheap but effective solid tri-fold tonneau cover
- full wheel and spare
- Start-X remote start kit to bring remote start functionality back to the keyfob
- wired in two forward bed lights into the existing circuit for better bed illumination
Ford F-150 Lightning What are some upgrades or Add-on done for the F-150 Lightning 20230331_194003
Blochead21
PA
Black 22 XLT 311pkg
What did you use for the front bed lights?
Gunnerbill
Gunnerbill
Las Vegas
Hell yah... I got tired of it falling on my arm. No, I just played around with it and placed a thick washer under the springs leg
ctuan13
Chuck
Pittsburgh, PA
ctuan13
Chuck
Pittsburgh, PA
Okay so here's what you'll need to do:
- Get the custom plug and play retrofit harnesses from @JHForman812
- get the factory Ford lights with their attached wiring from ebay or a local Ford dealer
- once you have everything, disassemble the top of your center console, and remove the glovebox
- install the retrofit harness
- install the lights and connect them
- enjoy
Gunnerbill
Gunnerbill
Las Vegas
- enjoy
Do you have a picture and link or factory Ford lights & retrofit harnesses
Found it, Order it directly from FORD, use part numbers
ML3Z-14A318-C Wiring Assembly Interior Lamp
ML3Z-14A411-C Glove Box Lamp
ML3Z-1513562-CB Cup Holder
It is a direct replacement, just need the harness, Thank you !!!
ctuan13
Chuck
Pittsburgh, PA
