- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
Would you mind sharing a bit more for your plans? I'm a full Insteon install for lighting control using Universal Devices ISY and I have Alexa for voice control which is integrated into the Honeywell thermostat and a few other devices.I suspect you could use home assistant + Apple Automator to make a shortcut for the garage door.
I’ve got a Ratgdo on order, so I’ll have to play when it arrives
I've just started following the Home Assistant thread and am curious at a high level if I added a Home Assistant device and the Ratgdo device if I'd be able to then Geofence the house and when arriving home have an automated garage door?
Have you thought through that enough or without research do you know the capabilities of those products combined to make that easily doable?
Edit - @LightningB514 just added a post as I was typing that may help clarify part of this although he is using Siri. If I go down a road of adding more automation, my desire is to go for hands off Geofenced automatic open.
