Brothers Charging Port Door Fell Off
The Weatherman
Dean
South Central KY
F150ROD
F150ROD
U.S. Navy Retired
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
It literally slides right back on. If you press to hard and at a specific angle when closing it you can push it off the little tabs that hold it on. Then you go driving and it goes missing.
biers
Thomas
SW Washington
eGolf
Haven’t had the cover off mine, but the plunger on it is terrible. Ford, please source from wherever Chrysler gets there for the Pacifica. It’s butter smooth by comparison. Takes 1/10th the force/effort
DennisM1
Dennis
Washington State
2022 Tesla Model 3 Long Range AWD; 2021 Ford F150
Attorney
My charge port is being replaced under warranty due to the door being extremely difficult to open or clpse. I am waiting for a mid-January dealer appointment now where parts were ordered.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2017 Tesla MS90d, 1941 Lincoln V12
I believe the chargeport door mechanism is the same as on some VW gascars. I was at a gas pump to buy diesel for my tractor. This was last summer. Next to me, a woman was trying to get the cover to open so she could buy gas. None of us nearby were able to help get it open. Sure hope that doesn’t happen to me. Afew days ago I didneedto use a heat gun to get mine open. It is a poor design.
DavePNW
Washington State
2023 XLT
... you can push it off the little tabs that hold it on ...
tl;dr: You can push off the little tabs that hold it on.
The cover has little tabs of its own, that it uses to hold onto the above-quoted little tabs of the door proper. Both material and size put the cover's tabs at a disadvantage compared to the things they're supposed to grab. The tiny prong near the cover's upper outboard corner, for example --if you try to re-attach the cover to the door proper, you'll find it pretty easy to break off. Maybe not in one try, or in two like I did. But you get all the tries you need, while you can still find the cover.
