You don't need to officially connect your Fordpass device to their FCSP, just plug it in and let her rip, monitor the {Charge Session} via the HOME tab when the charge commences, click the charge details button and the drop down list to see the KW rate.My dealer has an FCSP and that was something discussed before I went in on 1/11/24 for the BECM and BSM CSP updates and the Sync recall, but somehow that fell through the cracks. To really test it at the dealer, I'd have to connect my FordPass to their FCSP, etc., which is probably something they don't want to go through and I probably wouldn't either at whatever their hourly EV tech labor charge is , since I'm not sure that if it's really a FordPass issue, whether there's any "warranty" coverage there! Have a further update to follow on another mysterious charging rate change...
I'm curious if you'll see 7 KW if your still stuck at a 30 amp setting or if you will see 16-17 KW which is typical for an 80 amp setting that the dealers FCSP might be wired for (I hope they set it up for maximum capacity)
Like the 13 KW in this example:
