Charge now instead of wait for preferred charge time?
Parsnip
Kevin
'23 XLT SR
On my home charger (Grizzl-E) I have set preferred charge time based on my power providers best rates (11pm - 7am). So usually I plug in and it starts charging at 11 pm. Normally that is fine, but if I get home at 5 and want to top off to run some errands at 7pm, is there a way to to tell the truck to charge now (at 5pm) and not wait until 11 without turning off the preferred charging times? This would be a rare thing for me so I don't want to have to go in and change the settings every time.
If you have a restrictive time set up in your EVSE, there is nothing you can do in the truck to override it.
Parsnip
Kevin
'23 XLT SR
Actually, it is not set up on the charger(my fault, I was unclear above), it is set up in the truck/Ford Pass app as the location. The Grizzl-E is just a dumb charger. I am looking for something like a "charge now" button in the truck or Ford Pass app settings that will override the preferred charging times for that one time.
TheWoo
Manhattan, KS
For clarity, did you set up your preferred time in the FordPass app, or somehow through your Grizzl-E?
If through FordPass, after plugging in you can open the app, click on the "Waiting to Charge" notification at the bottom of the screen (mine below says "Charge Complete" since I charged overnight) and then there is a "Charge to 100%" button. If you hit it, it changes to "Resume schedule" and you could click it again when you have enough juice.
I don't know of a way to just charge on demand to your preferred max.
Ford F-150 Lightning Charge now instead of wait for preferred charge time? 1000005456
Ford F-150 Lightning Charge now instead of wait for preferred charge time? 1000005457
Parsnip
Kevin
'23 XLT SR
Hmmm... I haven't tried that yet. It might work. Will let you know. Thanks for the idea.
Parsnip
Kevin
'23 XLT SR
Just to close the loop - it worked as advertised. I plugged in at about 4:30 PM and the Ford Pass app showed that it would start charging at 11PM. I pressed the charge to 100% button and it immediately began charging. I let it charge for a while, and since I wasn't actually going anywhere that evening, pressed the "Stop Charging Button". The charging stopped and the button on the Ford Pass app changed to "Resume Schedule". I pressed Resume Schedule and the truck proceeded to charge at 11PM as normal. Thanks for the help @TheWoo
jimfigler
Orchard park, NY
Just go to the preferred charge times on the app and hit the dot to change it from "use preferred charge settings" to "charge to 100% when plugged in" then when you get home just hit the dot to switch it back.
Calvin H-C
Calvin
Nice to know that pressing "Charge to 100%" will make it charge now - we were trying to do this over the past weekend.
This is one of a handful of things that Ford did better on the Focus Electric that, for some reason, they have abandoned with the Lightning (and I'm guessing the MME).
On the FFE, you can switch between "Value Charge" (using the schedule) and "Charge Now" in the charge settings. Additionally, it gives you the chance to change it when you shut off the vehicle for about 10-15 seconds - precisely when you are most likely to want to change. No need to dig through the settings.
That said, I found it most useful to use it when I was at a public L2 charger and needed a charge at a time when Value Charging wouldn't allow it. The FFE doesn't know charging locations, so it either follows the schedule or not based on this setting. I guess Ford figured by adding charge locations, one would be less likely to have to switch between charging now and following the schedule.
TheWoo
Manhattan, KS
While this also works, I prefer to use the charge to 100% button as it's a one-time change. I don't have to remember to go back in and change it back.
pullinggs
Alta, CA
F-150 Lightning
I agree with you 1000%. There should be manual controls in the truck to control charging without having to resort to changing some default setting and/or using an app on your phone. The truck should be able to control itself and you should be able to control your truck.
