XLTTOM
- First Name
- Tom
- Dec 30, 2023
- Holland mi
- 2023 Lighting XLT
If you just plug in without going to app are you preconditioning
You need to set a schedule, either in the truck or via the Fordpass app.If you just plug in without going to app are you preconditioning
if the charging is occurring near your departure time. Yes. (e.g. Leaving at 7 AM and your charging occurs between 4 and 7am)So is plugging in better then nothing ?
Yes it is been pretty much agreed upon by the cold weather and experience lightning owner that preconditioning only is providing "optimal energy efficiency" if used on longer trips. Shorter daily commutes probably does not make sense.Not sure if anyone has done the math here at different temps to see if the power lost to heating the battery is less than the power you get back from a warm battery. Pulling some imaginary numbers out of my....hat here to make my point: If you have a standard battery at 100% SOC, and 90% power, you spend 2 KWh getting it to 100% power, you have recovered roughly 10 KWh. Then you drive 20 mile round trip and use up 10 KWh. Park the truck in driveway and battery pack gets cold again. So you loose 9KWh of that 10 KWh you recovered. you are still losing 1KWh (more if you were bellow 100% SOC when you left).
When I travel and I need the range, sometimes I do precondition but more often than not, I just charge before I leave and that heats up the battery. When I have enough juice for local drives, I just leave cold.
I love to see real numbers if someone has looked into it.
How many miles a day and week are you driving and what size pack (SR or ER)?That helps alot. I love the lightning but not very technically advanced. Thanks for the help.
You can do no harm by simply plugging in every time you get home as long as you have a charge limit set.That helps alot. I love the lightning but not very technically advanced. Thanks for the help.
I think there's some confusion here.So is plugging in better then nothing ?
Remote start warms the cabin. Preconditioning with a departure time warms the battery AND the cabin. Uses a lot more energy, and only gives value for a drive that is long enough to benefit from that battery warming.I have not idea if there is any real value to preconditioning the battery.
I do know that it is delightful to precondition for cabin comfort, especially an early morning departure.
