Twraps MagSafe charger for Lightning
Stang68
NJ
Mach E GT Performance, Lightning Lariat Extended
Hi all,
I have been using the Twraps MagSafe charger for my Mach E due to the Ford charger being awful, and was unsurprised to find the wireless charger in the Lightning also sucks.
So I reached out to Twraps on the Mach E forum to see if he would be interested in making one for the Lightning and long story short, we worked together to get the right measurements and tested a prototype.
After some adjustments, he has officially launched it on the Twraps store for purchase! I am enjoying mine and am so happy he decided to make one for us Lightning owners. It uses double-sided tape to stick to the stock wireless charger and easily fits my iPhone 15 Pro Max.
Photos of my “production version” below along with the link to purchase.
**I’m not affiliated with Twraps in any way and do not benefit financially from this at all…I just enjoy his MagSafe products and wanted to share.**
https://twraps.com/products/f150-lightning-magsafe-compatible-wireless-charger
Ford F-150 Lightning Twraps MagSafe charger for Lightning IMG_3462
Ford F-150 Lightning Twraps MagSafe charger for Lightning IMG_3457
Ford F-150 Lightning Twraps MagSafe charger for Lightning IMG_0177
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
Im really interested in a magsafe charger thatll sit on top of the wooden sliding lid. I have bigs hands and putting my hand in there i always get scratched by the lid mechanism or the tray.
mobilelingual
Ryan
South Florida
2023 Ford Lightning Lariat ER
Interesting idea however only 10W charging due to input power I assume. Haven't had an issues charging my iPhone 15 Pro Max on the factory wireless charger but no idea what kind of power it gets. Would definitely jump onboard if it was full 15W MagSafe or Qi2.
Stang68
Stang68
NJ
I have to assume the factory one is not giving 10W, a wireless charging pad like that is likely capping out at 7.5 but more likely 5w.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
You don't run into issues with the phone falling off the lip? Doesn't look like there is much clearance in the first few pictures and even less with your phone hanging off.
Stang68
Stang68
NJ
No, the phone is magnetically attached, that’s what MagSafe does with iPhones (and I guess compatible cases for Android devices).
Yep, his FAQ states:
How fast does it charge?
Our pucks are designed to allow up to 15W of charging power (for each puck). With that said, there are many constraints that may reduce this in real life. For instance:
* Your vehicle might not allow such power draw
* If you are using an iPhone, iOS limits non-Apple pucks to 7.5W.
* The charge level of your phone might also play a limiting factor.
Realistically speaking, most iPhone users would enjoy charging speeds around 7W, while customers with high-end Android phones might see charging speeds around 13W.
Stang68
Stang68
NJ
You may want to look into a charger then that would sit sort of vertically, maybe in a cup holder or in the cubby in front of the shifter? Because I don’t think you could get a MagSafe charger to sit on the tray cover without blocking access to the tray underneath (unless you don’t care about that tray!).
jmc6020
New Hampshire
2023 F-150 Lightning Lariat
invertedspear
AZ, USA
lightningcalcs.pages.dev
So will not work with the XLT or PRO. Please let him know he should state as much on his product listing.
Keanen
Keanen
MN
Software Engineering
Does the Twrap charger activate the OEM charger underneath it? I am wondering if it does because it would generate extra heat.
Stang68
Stang68
NJ
No, I don’t believe it does. Someone on the Mach E forum explained that wireless chargers only activate when a phone is trying to pull energy. I haven’t noticed any issues.
However it may be worth reaching out to Twraps for more info.
