RickKeen
Rick
F150L SR Pro
sw engineering manager,
Hauling the old hot tub cover to the refuse center along with the pallet and box from the new cover and some other cardboard.
Pallet is 56"+ wide x 96" long. Sits up on one wheel hump a little in the standard F150 bed.
(Would have had to have been loaded on edge if in a Cybertruck)
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 1713120794346-wh
ryun
Earth
Helped a friend haul some mulch. There's probably close to 2 yards in there which was prooooobably over weight by a few hundred pounds. 😅 Gonna avoid that much in the future so I can keep my suspension in good shape over the years, but the truck didn't seem to mind. Will also be lining the bed with a tarp next time -- the one I had was ripped more than I thought before I embarked on my trip. Aside from those hiccups no problems.
I also got the harbor freight unloader to work with some scrap wood screwed together and some ratchet straps since our tailgates are too wide.
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_0353
Jseis
SW Wa
Practicing being an excavation contractor. Buddy picked up the new mini X at Ritchie Bros a couple months ago for ~$2K and change. Impressive digger and excellent at finding old telecom cables 🙄!
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_3894
Ford Motor Company
Official Ford Account
Ford
F-150
That's right, Rick! And with on-board scaling, the F-150 Lightning makes sure you're never over capacity on anything you're hauling!
Ford Motor Company
Ford
F-150
That's awesome! We'd love to see more of that F-150 Lightning you've got tucked away!
Ford Motor Company
Ford
F-150
Truck things... Here I am using the F-150 Lightning's Pro Power Onboard to charge locomotive starting batteries. A locomotive's low voltage system is 64V and the lead acid starting batteries weigh about 3,500lbs.
Wow! That's incredible, Jamie! We bet you're the talk of the tailgate with that kind of display of the F-150 Lightning's power!
RickKeen
Rick
F150L SR Pro
This may be controversial, but I wish that the scale displayed how much over capacity the load is. Right now, it just maxes out. But there is a big difference between being 50lbs over and 1200lbs over and I would like to know that difference.
Also wish they would just display the current load as a number in lbs. The bar graph is not nearly as useful.
BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
I started building a playhouse for our kids in the backyard. Instead of walking back and forth between the garage and backyard I made my Lightning a mobile workshop with the PPO. Worked perfectly and made everything easier and quicker.
And to the ford engineer who thought of the clamping spots on the tailgate - thank you!
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_0661
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_0662
Ford F-150 Lightning Pics of Lightning Trucks Doing Truck Things. Post Yours! 📸 IMG_0663
Ford Motor Company
Ford
F-150
I started building a playhouse for our kids in the backyard. Instead of walking back and forth between the garage and backyard I make my Lightning a mobile workshop with the PPO. Worked perfectly and made everything easier and quicker.
We're glad you're enjoying the F-150 Lightning! Our teams worked hard to bring thoughtful design choices to life!
