Leer Hf650m compatibility/bed dimensions question.
starrtech2000
Colorado
23 Lightning Lariat ER 511a
The Lear hf650 is the only cover I can seem to find that meets my requirement for a folding bed cover that doesn’t block the camera when fully stowed.
The problem is that their website shows it as incompatible with the lightning. However, it shows as compatible with a regular F150 with the same size bed.
Does anyone know enough about the bed sizes to tell me why it wouldn’t work with the lightning?
as you can see in the screenshot, it says it is compatible with F150 crew cab with 67.1 inch bed, which I thought was the same dimensions as the lightning
Ford F-150 Lightning Leer Hf650m compatibility/bed dimensions question. IMG_9634
Bad website?
The bed is identical, yes.
VTbuckeye
Vermont
It works just fine. I have one.
FreshDaddyE
Raleigh
2023 F150 Lightning
I really wish this had a T-track option.
I'm probably going to end up with another RetraxPro XR for just that reason though I like the HF650M design better. :/
starrtech2000
Colorado
Did you see there is a new version of the Bak revolver that has a T-slot track? Just came out.
FreshDaddyE
Raleigh
2023 F150 Lightning
I did! That's a positive step. I hope there's a T-track option for most all covers in the future.
I'm sketchy on a soft cover so I'm hoping for a folder with T-track. Unless there's one I missed.
The Revolver isn't a soft cover.
WileyKyle
2022 F-150 Lightning SR
Can you open and close the power tailgate without lifting the Leer tonneau?
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
When the bed is fully opened can your cargo camera see over the cover and into the bed and the road on either side of the bed?
How much weight can you put on the cover when it is closed? (i.e. can you sit or stand on it?)
