Lightning xlt clicking noise when put in gear from park
Kit2874
Kit
Mississippi
F150 lightning
Like the title says when I go from park. To either neutral, reverse or drive. It makes a clicking noise and keeps clicking.
Any ideas?
Kit2874
Kit2874
Kit
Mississippi
F150 lightning
It might be it but this is what it sounds like
Ahhhhhhhhhhhhhhhhhh
Totally different issue, I have not heard of this situation before!!
rraustad
Richard
2023 F150 Lightning XLT SR
When I depress the button on the shifter, I don't move the shifter just depress the button, I hear 1 click that sounds like that.
ctuan13
Chuck
Pittsburgh, PA
That sounds like the shifter interlock actuator. There must be an issue with the range sensor in the shifter causing it to engage and disengage rapidly.
Ford Motor Company
Official Ford Account
Ford
F-150
Any ideas?
Hi Kit! I can look into your Lightning's noise concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN?
Kit2874
Kit2874
Kit
Mississippi
F150 lightning
Update
finally able to get it worked on, they have to change out the whole shifter assembly because of a locking actuator...
And also they found out the
SOBDMA module has to be replaced.
Joshua221
F150 lightning
I think there might be a limit switch that needs adjustment. Shifter in Park.
Sounds like a collapsed lifter. Is the sound 1x or 2x RPM? Hopefully it's not a rod knock. What's oil pressure look like? Of course it only happens while in gear so it's probably in the transmission. Have you checked the ATF level?😁
