100%/75%/50%/25% Depth of Charge Graph for NMC Batteries
Helium
Missouri
2022 F-150 Lightning
Several people have asked me about my charging habits on my high mileage Lightning. I did not realize it when I was doing it (I was doing it out of necessity), but I was actually complying with the recommendations derived from the below chart taken from the linked video. Though I don't think anyone on here will be surprised by the gathered evidence (yeah I know that evidence\research needs to be rigorously verified by others...), I do hope it informs your decisions.
I hope I return here in 2054 to celebrate my 1.6 million mile battery...how many sets of shocks, ball joints, tires, brake pads, seat upholstery, paint jobs is that going to be...
Ford F-150 Lightning 100%/75%/50%/25% Depth of Charge Graph for NMC Batteries StateOfDischargeGraph.PNG
sotek2345
Engineering Manager
Here is a summary slide, from the above video, that spells it out very cleanly:
Aren't we are 95% Ni content in our batteries?
Helium
Missouri
From what I have seen looking around the internet, though I can't find anything difinitive, I BELIEVE they are NMC94 batteries.
Joe.....Montana
Joe
Montana
2023 Lightning
My takeaway...if I'm going to hit that <70% battery warranty within 8 years I need to be roddin' like a hot dog and going 100% to 0% non stop for the next 7 years....
Helium
Missouri
Probably. I'm still not absolutely sure how much nickel we have in the battery. The last paragraph in the last slide I posted above indicates the single crystal positives with less than 70% nickel are worry free, but I'm pretty certain Lightning batteries have the something like 90% or 94% nickel. Still looking for an authoritative source on this.
Helium
Missouri
MickeyAO
Mickey
San Antonio Tx
94? 130%? Where did you see that number? And avoid it in the future. When listing chemistry, the numbers should equal 10, which is 100%. If you have a cell with 90% nickel and still has manganese and cobalt, you will have a 9.5.5
I really don't remember what the SKE805A is, and I really don't feel like looking it up tonight, but I'm pretty sure it is either 811 or 9.5.5
Helium
Missouri
Here is a screenshot from the video above that references a Ni94 battery. The video link below goes directly to the chart in the video:
Ford F-150 Lightning 100%/75%/50%/25% Depth of Charge Graph for NMC Batteries Ni94Table.PNG
Here's paper, there are a handful of others. I should have dropped a link into the original post above with the news article that had NCM94 in it:
https://www.sciencedirect.com/science/article/abs/pii/S1385894721056060
another
https://www.sciencedirect.com/science/article/abs/pii/S2095495621000802
" Based on the analysis of boron-doping and coating strategy on LiNi 0.94 Co 0.03 Mn 0.03 O 2 (NCM94) shown in Fig. 9, it can also be discovered that adopting B modification can significantly suppress H2-H3 phase transition by virtue of the stronger B-O bond, which stabilizes the TM-O slabs as well as the ionic-conductor coating (BPO 4). "
https://ui.adsabs.harvard.edu/abs/2022ChEnJ.43134031G/abstract
As far as the '130%", I'm not certain where I would have used such a number in relation to batteries or the lightning. Search the page, but I may be just to tired to see it.
SpaceEVDriver
Arizona
2023 Lightning, 2022 Mustang Mach-E
That comes from 9+4 = 13 => 130%.
A common (but unfortunately not universal) naming scheme for NCM is to append numbers related to the stoichiometry of the Ni, Co, and Mn. So one reading of NCM94 can be that it's 90% Ni, 40% Co+Mn, thus 130% of the possible 100%.
However, the actual chemistry of that particular battery is LiNi0.94Co0.055Mn0.005O2 (94% Ni, 5.5% Co, 0.5% Mn), so the authors of the paper seem to be using a different naming convention.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
Great info.
What excites me most about EVs is that although most of the the focus is on how long the battery will last, the reality is that they'll not only last a very long time, but they're also easily swapped.
Even if your battery doesn't reach the 1.6 million mile goal, it's possible that at some point there may even be improvements to battery tech that can be swapped.
I'm sure by 2054 there will still be a market for classic cars and trucks and we'll see people restoring older EVs by swapping batteries for the latest tech, and at a much lower cost. Who knows, by then we'll see EVs running off solid state graphene or even salt water based batteries.
Helium
Missouri
Thank you for the explanation! (Starting my day off with a little dopamine hit is a good way to start the day! :))
