Lightning won't start!!
Gimme_my_MME
Got any aftermarket accessories?
Pro or NO
Will
Pa
14 F150 ecoboost
Areospace machinist
I had the same problem at 6 weeks old. Probably a fluke problem, but it had a damaged wiring harness at the high voltage battery. By damaged I mean it was already corroded enough from salt to cause problems. It must have been missing the seal in the connector. 4 1/2 week wait for a couple wires. Judging by the part numbers i saw it was the roundish white connector in the photo.
Ford F-150 Lightning Lightning won't start!! pack
WileyKyle
2022 F-150 Lightning SR
Dealer says it's the Battery Management Module and 2 other modules attached to the main battery. They don't have a timeline on when they will receive the parts. :cry:
If it were me, I would keep meticulous records of everything going on right now. Write down notes of conversations had between you, Ford and the dealer. And get ready to file for a buyback. Also, look into the lemon laws of your state.
Ford Motor Company
Official Ford Account
Ford
F-150
This is the second time this has happened in 2 weeks. I park the truck in my garage and when I go to drive it a few hours later I get the "Stop safely now" message and it will only enter "accessory mode". No alerts on my phone or explanation in the truck. Any help would be appreciated..
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this no start concern? Thank you!
Reading your latest thread about connectivity problems, what was the end result / resolution from this issue?
