NCMike
- Mar 24, 2022
- Raleigh, NC
- 2022 Red Lariat Lightning
Dog mode is just less menu button pushes to achieve the same result. We want to be able to tap the climate controls then tap a dog mode button and then leave the truck, so 2 taps of the screen.1) More Range, as well as different battery chemistry that is not harmful to charge to 100% regularly, and degrades slower over time.
2) More space in between the top of the door frame and the seat. I have to tilt my head straight down to squeeze into the driver seat to get in and out of this truck.
Can someone tell me why dog mode is being requested so often?
Iām not sure the difference between simply turning it on, locking it, and walking away, other than a note on the infotainment system? Please forgive me if this is a dumb question, Iām just not familiar with what it does on other vehicles.
Currently we have to tap the options at the top of the screen, wait for it to load, then tap the vehicle options, then deselect the power down timer. (if not the truck shuts down after 30 minutes) Then wait for a pop up that tells up vehicle will shutdown once pro-power milage threshold is met. Then I have have to go back to options, select pro power, and then make sure the mileage is set low enough that I know the truck will not turn off while I am away. So for me that's 5 or 6 taps plus the time it takes for each screen to load which feels like the software is getting more sluggish.
