Smokewagun
- First Name
- Bob
- Jun 7, 2021
- N. Illinois
- 2019 Ford F-150 Lariat 3.0L Stroke
You make charging station selections sound like walking down the aisles at Walmart and selecting crushed pineapple from a myriad of choices. In the Midwest, unless you are in a big city, good luck. And, if the trucks charger dictates the max rate, on a SR, is the 350kW gaining you anything over the 150kW? Not much, if any. They both drop down to below 150 in a relatively quick manner.Just curious why “the SR makes it a challenge” (as in, having an ER with another 26kWh really makes a huge difference??). SR requires one (worst case two) more charging stop than ER in 450mi. Challenge? Not in my SR experience- just avoid chargers that don’t output 500A. Stick with EA 350kW (500A), avoid the 150kW (only 350A), and don’t even consider anything under 150kW, on a long road trip. Avoid routes that require 50kW charging-they’re not suitable for EV road tripping, imho.
