Electrified Marina
Ricky
Norfolk
www.ElectrifiedMarina.com
Ford Lightning, Model 3, Model Y
Marina Employee
That boat is gorgeous. I wouldn't mind some boat tour pics if you had em.
When I'm feeling the kWh/mi crunch I slow down to ~60max and turn on "performance mode" (not available when towing I assume) but I've been getting remarkably better numbers doing that.
I think there would be a market for aero wheel covers-- even though they'd look universally worse, having the increase in efficiency would make up for it. I ran quite a search on them and couldn't find much at all.
Check out this review on boattest.com
Ford F-150 Lightning Towing 1.0 kWh/mile (7,000 lb boat) 1000009341
Jasper7821
Ken
Tucson
Lightning Lariat
Aircraft researcher
I tow my 2,300lb boat with the Lightning and at 70 it’s 1.4, 65mph is 1.6, and 55 is 1.9mi/kwh.
Towing with the Cybertruck is about the same.
Ford F-150 Lightning Towing 1.0 kWh/mile (7,000 lb boat) IMG_3669
Ford F-150 Lightning Towing 1.0 kWh/mile (7,000 lb boat) IMG_4048
subseavet
Herndon, VA
2023 Ford F150 Lightning Lariat Extended Range
R&D Engineer
Right. A2ZEV makes the Typhoon Pro adapter for Tesla SuperChargers. It sells for $193.50 (after using code FORDFORUM). They also sell the Stellar adapter, which is for Tesla Destination chargers. It sells for $110. If you pick use the dropdown menu on the Typhoon Pro page to pick the Stellar adapter also, the combined price is $261, 20% off. In other words, it’s only $67.50 more for the destination charging adapter. Delivery is normally 2-3 weeks. I have both adapters and have used both many times. They work great. https://a2zevshop.com/products/nacs-ccs1?ref=Typhoon&variant=43186507579592
I have both of them myself and agree 100% with Rick. The A2Z adapters work great. And super fast!
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Me after I just looked up the price of those X Shore boats.:oops:
Well, for the price difference between the CT and a Lightning Pro, you might not be able to afford an electric boat, but you can afford a nice wakeboat.
Ford F-150 Lightning Towing 1.0 kWh/mile (7,000 lb boat) 1722636352633-zj
Or maybe a relaxing pontoon:
Ford F-150 Lightning Towing 1.0 kWh/mile (7,000 lb boat) 1722636599178-1k
Electrified Marina
Ricky
Norfolk
Marina Employee
Nice ... cool that you can do a direct coparison!
