Anyone using the Kwick Strike in their truck?
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
I have a Console Vault and @BestEvMod tray for it and they are awesome when I need to lock up and hide stuff. I was looking at the Kwick Strike and was wondering if anyone had tried this in their truck and how it fits. Another option is lose weight šŸ¤£.
AZT9
Peoria, AZ
Iā€™ve looked Into it too. But Iā€™m not sure how it will fit between the seat and center console as itā€™s a pretty tight space. For now it remains IWB APPENDIX OR in my door holster
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Curious about your door holster configuration if you'd be willing to share.
Runaway Tractor
Yes
I'm not seeing where that will fit between the seats. There's barely room for a french fry to fall down there.
IMO a firearm in a vehicle needs to be either on your hip or secured completely out of sight still in the holster (console vault or lock box under the seat for example). All those things that attach it to the dash or exposed on the center console are very bad OpSec and asking to be stolen. Most of them also require unhostering the handgun to place it in the device.
Thank you for the reference to the BestEVmod console vault compatible tray!! I've been looking for something like that.
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
The French fry comment is exactly why I'm seeing if someone had tried it :). It's a tight fit there. I currently run the Console Vault with an Alias mount that holds my IWB holster under the lid when I need to secure it for some reason. I mounted the Alias with screws because I got it before the magnetic version cam out.
Ford F-150 Lightning Anyone using the Kwick Strike in their truck? IMG_8217
Just always looking for refinements.
The concealment of the vault under the tray is awesome. Very thankful @HaroldCal helped them get it done.
I didn't want to hijack the other thread to talk pew pew placement.
AZT9
Peoria, AZ
Not much to it. I use a hidden hybrid for my IWB. Grabbed one of my kydex with the large utili-clip and clip it to the lower door pocket. Helps that Iā€™m a south paw tho
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
I need to work on my ambidextrous skills.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Here in California, I'm packing a rubber band shooter and super soaker.
Rick
Avocadodude
Avocadodude
Kurt
Fallbrook, CA
F150 Lariat
Rick
I was thinking one of these for my trips to LA, but felt it would reduce range šŸ¤£.
Ford F-150 Lightning Anyone using the Kwick Strike in their truck? 1723821905117-7s
Runaway Tractor
Yes
I plan to never go near LA. But if I must, I'm not doin it with anything less than a C-RAM on a trailer.
