PTS/FDRS VIN Check Thread
ChippewaBarr
23 Lightning Platinum Agate Black
Your warranty history says it was performed on 6 March along with the BMS sensor replacement.
The only update you show available in FDRS is a TCU update.
Sorry for the delay, pat leave has been wild!
But oh man 🤦‍♂️ the dealership said I had to wait until it was released later this year to get it done lol.
One of the Techs seems like he is very in tune with EVs but the others in the dealership are completely lost it seems! But thanks for the info!
jlcreasy
2023 Lightning Lariat
Can someone check VIn 1FTVW1EV6PWG28862? Curious if any new updates have dropped in the past month. As always, much appreciated!
2021 Ford F150 Platinum FX4 EcoBoost
Only showing a GWM update.
jlcreasy
Well, that's a first since you did the BCM update for me a couple months ago. Guess I'll give it push if nothing happens soon. Thanks as always!
I would not expect anything major to be released until either the powertrain updates are made available again or the new version BC makes its way over here.
dustintinsley
Dustin
Salem, CT
1FT6W1EV3PWG50077
Can anyone see if any updates are there. Specifically, the APIM/GWM/TCU modules. Thanks!
1FT6W1EV3PWG50077
You're showing two out of three of those.
Ford F-150 Lightning PTS/FDRS VIN Check Thread 1723904007500-ks
Without the APIM update I would still not be on the latest SYNC, correct?
Not quite. You're on Sync 23159 which is one version behind the latest. Once these install, it should release the APIM update you're missing to be at the latest Sync version.
dustintinsley
Dustin
Salem, CT
When you say it should release it, how long would that generally take?
Usually immediately after the update that precedes it installs. So, if you were to get the GWM via OTA, the APIM will show right after (as long as the OTA process goes the way it is supposed to and the vehicle reports itself back to the server once the update installs).
dustintinsley
Dustin
Salem, CT
What if I update via FDRS?
Then it should release right away because FDRS will force a sync after every update.
Edit: With FDRS, if the APIM does not release, message me.
dustintinsley
Dustin
Salem, CT
Sounds good. I guess it would be worth buying a 48 hour license to go ahead and knock these out. I will let you know about the APIM
dustintinsley
Dustin
Salem, CT
The GWM update is the first I have requiring a USB drive. How long should the GWM generally take?
