Can't get ford adaptor to work at tesla stations.
moder8tor
Prescott AZ
23 F150 Lariat Lightning, 18 F250 Lariat Diesel
hard worker
Locking the adapter is the most common problem, but be sure you have a valid verified form of payment configured in the Tesla app.. Same thing for Plug n Charge otherwise you can also see a fault...
Yep, thanks, verified all info in the tesla app. I will mess with the lock button/lever
Try to pull the adapter off of the tesla cable. Everything should be securely latched together and you should not be able to pull anything apart.
MyJoule
'22 F150 Lightning Platinum
My first attempt ended in failure too- I couldn't 'get the lock to engage- I moved over one stall and it worked fine I've had no issues since either. I wonder if the handle at the first station was bad? Some people have had trouble. If you continue to have trouble give A2Z a call. they may have an idea how to help- maybe even send you the Typhoon pro which has the lock on top instead of the bottom
1Jetpilot
Jerry
Port Clinton, OH
2023 F150 Lightning Lariat ER
Retired Pilot
at least you got your adaptor
Exact same.
Unfortunately the one that did NOT work was the end spot too!
Rip
Rip
2024 Lightning Platinum
Quality Consultant
Assuming you are using the Tesla app, make sure you put in your vehicle and indicated you have an adapter. Put adapter securely on nozzle, then plug in.
If you aren't paying for the Tesla membership discount, just use Plug and Charge.
What is the "Tesla membership discount?"
