Range display changed after a short trailer tow
ED_C
Ed
North Vancouver
Tesla S, Tesla s, Ford lightning 150
I pulled a small utility trailer, plugged in the lights. the range display reduced my KM travel range. I understand that my range will be lowered due to a trailer tow. The display still shows a reduced range even though the trailer is no longer being used. How to I reset the range indicator?
Go to the trailer screen and select “No trailer.”
ED_C
Ed
North Vancouver
I will look again for that screen. thanks.
Adventureboy
The trick is to unplug the trailer electrics while the truck is on. If you turn off the truck, then disconnect the trailer lights, the truck still thinks a trailer is attached and you need to go to the settings and tell it otherwise. @Ford Motor Company could fix this, but haven't yet.
