thequackenbush
Ryan
Marketing
The cable/satellite guy(s) sure left a mess. šŸ˜‚
Oh my god man, I donā€™t think Iā€™ve ever really looked closely at that before this week
I Ripped out so many disconnected wires and cables and boxes and feel like I barely made a dent.
This thread was an inspiration. The selling point of the lightning acting like a portable generator was amazing to me, but the price point of the home integration system was a no go
After reading through all this, had the install done the past two days. Ignore the panel labels; we also freed up a ton of space, identitied a bunch of unused circuits (house was built in the 30s) and cleared a bunch of room to install the FCSP
Love this truck
Were you able to successfully test it?
thequackenbush
Ryan
Marketing
Yes! After some trial and error, it worked great.
Except for one of the circuits which, when turned on, continually tripped the truck breaker. However, we think this is likely because of the age of the wire of the circuit and the sensitivity of the truck.
We'll swap it out with a different circuit in the near future. Overall, really pleased with the results.
thequackenbush
Ryan
Marketing
What can you run in your home with that set up?
My Generac is supporting:
refrigerator
furnace/hot water (we have oil)
kitchen outlets
living room outlets / lights
my and my kids bedrooms (same circuit)
range oven (gas oven, electric only needed for clock / thermostat)
If the truck says the circuit is ground faulting it's because ground is touching neutral in the circuit. You can troubleshoot it if you want but if swapping into a different circuit suits your needs maybe it isn't worth the time and effort.
thequackenbush
Ryan
Marketing
That's great to know- we found a really really messy junction box that we think has something to do with this, but it was late in the day and didn't have overall time to address it.
It could also be that the neutral of this circuit was inadvertently connected to the neutral of another circuit. Handymen like to connect all neutrals together in a junction box, even if from a different circuit.
Indeed! The first step while troubleshooting should be to unplug everything that is known to be on the circuit in order to determine if it's in the wiring itself. In my case it was a fireplace fan that some incompetent baffoon (me) had wired wrong.šŸ¤¦ā€ā™‚ļø
