Brake Pedal Noise on 2024 Flash
Mars_Tuesday
Asif
2024 F-150 Lightning Flash
The brake pedal on my 2024 Flash make a squeaking sound when depressed (even when the car is turned off). Couple of other 2024 Lightning owners on Reddit, confirmed having the same issue on their trucks. My brothers 2022 XLT or my cousin’s 2023 Lariat Lightnings don't have the squeaky noise when pressing the brake pedal. What did Ford change for the worse to make the brake pedal noisy? I’ve attached a video of the issue in question.
My 2022 does that. Mechanic said most do. NORMAL.
Normal.
BTW, this thread caused an immediate duplication, be on look out for multiple thread creations that I may need to clean up, please use the report function if you see more instances.
Maineiac12
Iowa
Did you ever take this in to the dealer? Mine started making this noise when it got cold recently but my first lightning did not. Kind of annoying.
Mars_Tuesday
Asif
I took it to the dealer, but to my surprise, every single 2024 on the lot made similar noise. The dealer said there was a change in brake hold mechanism that’s causing the noise on late 2023’s and all 2024 models, and that it was within spec. It’s annoying as hell. I’ve driven over 3000 miles already on my truck, and it still bothers me like it did on day one.
