azDcab21
I emailed my local Linex shop with questions about the prep steps they use when applying Linex. Thought it might be useful to others. I imagine that all Linex installers should follow a similar procedure.
(1) We remove the OB power box and spray behind it.
(2) We remove tie downs and bed bolts at customer request.
(3) We tape off the led Lights and remove/reinstall button.
(4) We leave rubber drains plugs in and spray over them.
(5) We will remove tailgate and spray it upon request. It is only a 2 inch border we will spray, Behind that cover is just an open tailgate.
(6) We use 80- grit sand paper to prep the bed sanding just the clear coat only and cleaning the extremely well before spray. we only install the bed of the truck in our booth dropping a plastic wall to separate the cab from the bed.
