Does anyone else have door rubbing when driving?
mdlightningIL
Martin
2024 Ford F-150 Lightning
Insurance
@astrand1
@Firn
Thank you!
OK, it looks like this did it. Such a quick and easy fix to this significant door vibration. The door moved around a millimeter and that did it. Unreal how a small amount of movement made that much of a difference. I also see where another owner tried this today too!
I added an image of the movement amount. Before the fix, the black trim was even. Not even concerned about moving the rear door to line up. You can barely see it. Can’t wait to call the dealership and cancel the service appointment :) !
OK, now to tires haha. Any thoughts on the Toyo Open Country AT/3 EV LT vs XL? Really trying to decide if the LT extra ply construction is really needed or if the XL will do it. I’ll be going off road but not rock climbing. We’re talking dirt roads. No massive towing. Truck bed tent when camping. Let me know if y’all have heard about these Toyos.
@Discount Tire
If there is anyone monitoring your account, I tried getting these from the Bloomington/Normal, IL store and they had no interest in finding them for me. I have seen where other stores have found these tires for folks by ordering. Could I get some help getting these?
Ford F-150 Lightning Does anyone else have door rubbing when driving? IMG_4875
mdlightningIL
Martin
Insurance
What’s up door fam. Got down to 18 here in IL today and my previously silent door is on the move again. Now, I’m sure it’s because of the temp. Should probably grateful the last fix worked…but I’m wondering if moving the striker a small amount would wrap this door situation up? Has anyone move the striker and if so, any tips?
mxg249
J
2024 F150 Lightning Lariat
2024 Lariat ER with 300 miles on odo. My driver's door is doing this and it's enough to drive me crazy. I am not mechanically inclined and have bad luck so I'm afraid to adjust the door myself. It's going to my dealer's bodyshop next week. This is my first Ford and unfortunately not a great first impression. I'll update after the body shop visit.
mdlightningIL
Martin
Insurance
Strike that striker idea. I just adjusted the door on the bottom. Moved it slightly outward and this moved the top of the door further inward. The adjustments using the two bolts now has the driver door closing just as snugly as the other doors. It’s 15 degrees out and just took a drive to test. Like a vault :) This really nice vehicle just got even nicer. Have driven EVs since 2016. Multiple models from VW, Chevrolet, Tesla, and Rivian. This is without a doubt the best made EV I’ve owned. Best suspension by far and that includes the air versions from Tesla and Rivian. Such a surprise. And don’t get my started on the interior fit and finish. This Lightning takes 1st place.
mdlightningIL
Martin
Insurance
Good luck at the dealership. I would directly ask them to adjust the doors according to the method discussed in this thread. This method is truly the fix. If they don’t complete the fix, I’d suggest getting a friend to help. It’s not too bad honestly.
Maineiac12
Iowa
Thank you! I just fixed my driver door rattle!
Best of luck. I had the dealership look into this issue for me, they even called in an aerodynamics specialist from Ford (supposedly).
Zero change
One wrench, one bolt (that you don't even take out), and two minutes later it was fixed.
If you want i could try and take a video for you.
mxg249
J
Zero change
If you could take a video, that would be awesome! What's really holding me back is once I would unloosen the bolt, I can't visualize how I would "move" or manipulate the door to get it closer to the frame.
Caliber357x
‘23 Lightning Platinum
Ok. So 2 pics. First wide shot of the 2 hinges on door. Then the closer on is the top hinge with my meat nugget pointing at it. That’s the one. Just loosen that one very little and that will allow the door to pivot in on the top half. I would suggest just moving it in a small amount then tighten and go for a ride to see if it’s better. Mine had to just pretty much go all the way in. Before I did this you could see the top half of the driver door sitting proud of the rear door. Now it’s flush.
Thank you for posting this! I have the same vertical rub sound with some wind buffering when I hit rough road and I think this will fix the problem!!
mdlightningIL
Martin
Insurance
Thank you for the pics and solution. I had to use a 13mm socket on mine, the 10 was too small but it fixed the problem. You were right, only loosen it a bit. I went a bit too much and had to re-balance the whole door. Whoops
@mgmessner89
Just adjusted the door and is nice and snug. I now notice just a slight sag in the door and need to get that nudged back up a hair. Can you describe how you were able to do this? Sounds like you also had the door move up or down as well as the side to side motion that actually seals the door up/resolved the issue. Thanks for the time and help!
lightspeed
2023 Lightning Lariat ER
Thanks for putting this up. I have the same issue.
Just to ask a dumb question, when in the video you say "towards you" what does that mean exactly?
If the door is fully open so it is nearly perpendicular with the truck side, and you loosen that bolt, it looks like you would move the door horizontally along the direction of the side of the truck towards where you are standing.
Is it easy to see how much it's moving from it's original position? It doesn't seem like that bolt hole should offer more than a millimeter or two of slop tolerance.
You have it.
You want to move the top of the door frame in towards the body, to tighten up the pressure on the seals. When you losen the bolt you need to move the door inward, towards where you are standing, towards the body/cab.
There is not a huge amount of movement, maybe just a few mm in total.
