marc_hanna
- First Name
- Marc
- May 16, 2024
- Nova Scotia
- 2023 F-150 Lightning Lariat ER
Since last Wednesday the 8th, my truck has had a strange issue that the dealer has been unable to fix. So far, the problem seems to be triggered by preconditioning the cabin through the Fordpass app. Basically, the truck is completely immobilized. Accessories will come on, but the truck cannot be shifted out of park. In order to get the truck into neutral, for towing purposes, you cannot use the instructions in the manual, but rather you have to press in both the brake and the accelerator with the accessories on and then pull it into neutral and press the temporary neutral button.
The first time it happened was after a day of driving, and the 12v battery simultaneously failed. We are not sure if these are related or coincidental. There was a stop vehicle immediately alert and a PWS alert. The Start button will not go solid when pressed, it will only flash.
Each time it was “fixed”, three times now, the technician was able to drive the truck and everything seemed fine. The common event before each occurrence, was preconditioning the cabin, which failed, according to the app.
Fixes so far include: replacement of 12v battery, which was done next day, and major software update of all systems which took 2 full days.
