So basically Ken Garff Ford of Cheyenne, sold me low in model lightning at a premium price. I can't even add this option afterwards.Yes it's an option called 9.6 kW Pro Power Onboard. No way to add it after the fact. For 2024 it was standard on Platinum, $1200 option all other trims.
You're not the first. Never trust a salesman and always look at sticker.So basically Ken Garff Ford of Cheyenne, sold me low in model lightning at a premium price. I can't even add this option afterwards.
Most of the Flash models I looked at didnโt have the Pro Power 9.6 or Max Tow (Packaged together). We all make mistakes on truck orders. I forgot to specify a bedliner or the all season tires over the AT, my bad but it doesnโt mean the truck is a low model.So basically Ken Garff Ford of Cheyenne, sold me low in model lightning at a premium price. I can't even add this option afterwards.
Not sure on this one. I do know the Flash didnโt get the 80 amp charge capability to fully use the 80 amps of the Ford charger.Does this also mean that the house backup feature with the Ford Pro charger will not work on my truck? The features in the console say that I have Pro power on board, and it warned me once that it shut it off because the battery was too low.
You may have the Pro Power Onboard 2.4 kW. Here is what I found doing a search:Does this also mean that the house backup feature with the Ford Pro charger will not work on my truck? The features in the console say that I have Pro power on board, and it warned me once that it shut it off because the battery was too low.
I should have added in my first reply that Ford offers two version of ProPower for the Lightning. So your dealer was correct if they said it had ProPower.Does this also mean that the house backup feature with the Ford Pro charger will not work on my truck? The features in the console say that I have Pro power on board, and it warned me once that it shut it off because the battery was too low.
He didnโt state if his truck was SR or ER. I seem to recall that SRs require some special software update ($$) in order to interface to the HIS.I should have added in my first reply that Ford offers two version of ProPower for the Lightning. So your dealer was correct if they said it had ProPower.
2.4kW Pro Power Onboard โ 120V outlets: two in the cab, two in the bed and four in the frunk, Standard on all trims but Platinum for 2024.
9.6kW Pro Power Onboard โ 120V outlets: two in the cab, four in the bed and four in the front trunk, plus a 240V 30A outlet in the bed. Standard on Platinum, optional on all other trims for 2024.
I'm pretty sure you can install the Home Integration System. It does not use the ProPower but interfaces directly with the HVB. It's expensive though. Need more that just the Charge Station Pro. Lots of threads on here if you search it. Here's one:https://www.f150lightningforum.com/...on-system-battery-installation-project.21020/
Note most folks use the 240-volt 30 amp outlet to power their panel through various connection means. Max load is 7200 Watts. The HIS system can go up to 9600 Watts.
Not an update, just a $500 payment.He didnโt state if his truck was SR or ER. I seem to recall that SRs require some special software update ($$) in order to interface to the HIS.
He said that he has a Flash. so it's an ER battery.He didnโt state if his truck was SR or ER. I seem to recall that SRs require some special software update ($$) in order to interface to the HIS.
Home Backup Power works with all F-150 Lightnings, but requires the Ford Charge Station Pro home charger and the Home Integration System available through Sunrun. When those are installed together in your home, any F-150 Lightning can provide your home backup.Does this also mean that the house backup feature with the Ford Pro charger will not work on my truck? The features in the console say that I have Pro power on board, and it warned me once that it shut it off because the battery was too low.
Not sure what you have and what you were sold, but the house backup feature requires another "kit" (Home Integration System) in addition to just the truck and the Pro charger.Does this also mean that the house backup feature with the Ford Pro charger will not work on my truck?
