broncoaz
Cape Cod, MA
I installed something similar on my 2024 Flash last week. I used a plug in harness from Diode Dynamics that allows for both backlighting and reverse function. I made some stainless steel brackets to bolt the lights on, no holes drilled in the truck. There is a newer light option from them with an additional brighter red brake light, but this is an older set I had.
https://www.diodedynamics.com/stage...DYYcK3AdLCQhuo-P29j0mhfHImLaElk8aAgAzEALw_wcB
Ford F-150 Lightning Great Easy Lighting Mod (LED Pods Backup Lights) IMG_0403
Ford F-150 Lightning Great Easy Lighting Mod (LED Pods Backup Lights) IMG_0404
Ford F-150 Lightning Great Easy Lighting Mod (LED Pods Backup Lights) IMG_0407
Ford F-150 Lightning Great Easy Lighting Mod (LED Pods Backup Lights) IMG_0408
21st Century Truck
Martin
I have something very similar on my truck - the Diode Dynamics Hitchmount reverse light + strobe brake light. Easy plug & play wiring loom, a 10-minute job at most to wire it.
https://www.diodedynamics.com/hitchmount-led-pod-reverse-kit.html
It inserts into the hitch receiver. It supplements the IMHO inadequate reverse / backup light on our trucks very well, with a white spot beam along the ground.
The really nice factor about this removable hitch receiver 3d brake light / running light / bright reverse light is that when I have the teardrop trailer hooked up, I just transfer the hitch receiver light module to the teardrop's 2-inch bicycle rack hitch receiver. Of course, I had to run the extension cord, available from Diode Dynamics, along the frame of the teardrop.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 37 years. Worked on everything from Lawn mowers to Boeing 747's.
And add one of these wired to the lights. Only if you don't want to tap into the wires. Which I will do after winter. This and the other adapter are pretty bulky.
Ford F-150 Lightning Great Easy Lighting Mod (LED Pods Backup Lights) Screenshot_20250114_123848_Amazon Shoppin
