SSNutz
- First Name
- Troy
- Sep 25, 2024
- SE Wisconsin
- 2024 Flash
- Occupation
- Sr Process Innovation Specialist
Ok, I am hoping to understand if I am doing thing wrong or Fordpass app is wonky. I have a 2024 Flash trim.
So I have been having "unpredictable" climate control failures. Some may have to do with connective issues, but that is not my concern. To explain; when get this message:
I still can lock and unlock my doors, so connectivity is not it.
Today I did what the message said and started my truck. And bang the climate control worked again. Waited an hour and still worked as some thought it might go into a deep sleep. Then I wondered ...I had my departure time active before so I turn that on:
Immediately I get the Climate Command Failed message when I try it. The truck was not plugged in but I did have Prepare Cabin Off Plug selected. So I turn off departure time, started and stopped the truck. Climate Command worked.
Plugged in truck, departure time still off and Climate Command worked.
Keeped it plugged in with departure time active and got the Climate Command Failed message....is this how it works for everyone else?
