Climate Control issues - Setting Departure Time Schedule is messing with function.
SSNutz
Troy
SE Wisconsin
2024 Flash
Sr Process Innovation Specialist
Ok, I am hoping to understand if I am doing thing wrong or Fordpass app is wonky. I have a 2024 Flash trim.
So I have been having "unpredictable" climate control failures. Some may have to do with connective issues, but that is not my concern. To explain; when get this message:
Ford F-150 Lightning Climate Control issues - Setting Departure Time Schedule is messing with function. Screenshot_20250122_090548_FordPass
I still can lock and unlock my doors, so connectivity is not it.
Today I did what the message said and started my truck. And bang the climate control worked again. Waited an hour and still worked as some thought it might go into a deep sleep. Then I wondered ?...I had my departure time active before so I turn that on:
Ford F-150 Lightning Climate Control issues - Setting Departure Time Schedule is messing with function. Screenshot_20250122_121546_FordPass
Immediately I get the Climate Command Failed message when I try it. The truck was not plugged in but I did have Prepare Cabin Off Plug selected. So I turn off departure time, started and stopped the truck. Climate Command worked.
Plugged in truck, departure time still off and Climate Command worked.
Keeped it plugged in with departure time active and got the Climate Command Failed message....is this how it works for everyone else?
Robob
Rob
VT, USA
24โ€™ Flash
Auto Parts & Paint/Body Supplies
I had something similar happen on my 24' Flash where it would pre-condition at a -2 or -3 hour offset to my set times.
The fix I found was to log out of all devices on ford pass and then do a factory reset under settings/general/reset and then reset the ford pass options on the truck.
You will have to re-set up your charging times and departure times but after doing this twice it seems to be fine.
The "climate command failed" only happens to me after the truck has been remote started twice or once and extended. Or if preconditioning is going on and you open the app and try to remote start right after it finishes is when I see this error.
Either way I would give the reset a shot in the options, just be ready to set up times again.
Keep in mind, as you're testing this functionality that you are allowed only two requests between KEY ON / RUN truck actions.
SSNutz
Troy
SE Wisconsin
2024 Flash
Thanks and I will keep this in mind. As far as I know the Climate Command Fails on the first try when I have a Departure time "on" and works when I have it "off". Are there other "run options" that truck might start that I am not aware of?
Other flash owners on another thread are complaining about remote start, departure timer and impromptu charging activities, and possible malfunction associate with being plugged in where charge has reached desired SOC and EVSE is on standby.
Make sure time setting on truck clock is accurate, AM/PM or MIL time.
SSNutz
Troy
SE Wisconsin
2024 Flash
Thanks, those items did check out ok. I emailed Ford and said said they get back to me. I will post the response when I get it. Hope it helps others.
