Squirrel Chewed Through Charging Wires
VTbuckeye
Vermont
For those with a garage, the best trick I've ever seen / read about is the ol' water bucket with a wire from edge to edge and a soda can or plastic water bottle or a similar round cylinder placed on a horizontal axis in the center of the wire, smeared with peanut butter.
The rat smells the peanut butter, climbs across the wire onto the can, the can rotates and rotates, the rat falls into water in the bucket, can't climb out...
...and the garage owner can count the harvest.
Too bad my garage gets cold enough for the water to freeze.
A few years ago some squirrels made my sailboat their winter/spring home. I never saw the adult, but there were four little cute fur balls in various places on the boat. They destroyed some dock line and one large and one medium sized fender. The line was turned into polyester fluff. The large fender was opened and became their nest of rubber pellets and polyester fibers. They chewed on the wood steps and the polycarbonate hatch cover. They chewed up some of the wiring, no more power for the radio or knot meter, (I just day sail and haven't used the instruments in years). The battery isn't on the boat, the outboard and bracket live in the garage.
I trapped them all and brought them to a couple different trailheads where I run/mountain bike. I really do not hold it against them for finding a dry protected space to make a home.
I don't worry about that now because my 14 year old has turned the boat into a giant fort for the winter. It's their safe space. Trying to figure out how they want to run the rigging differently this year and spend my money.
evowner
Frank
SW Ohio
Retired EE
If I was a squirrel I would move into a sailboat too. Only I would be quiet and hide, not destructive, so I could go sailing too.
VTbuckeye
Vermont
It spends the winter on a trailer in the backyard. Cheapest storage ever...
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 2024 Lightning Lariat AMB
I’ve tried cayene in my bird feeders, with some mixed results. I may not be diligent enough in using it.
pro tip: avoid applying when breezy outside
OMO7
23 Lightning
If I caught the squirrel that did that he would've wished he chewed through the HVB.
GarageMahal
JT
Data Wrangler
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Looks real clean for a rodent chewing all 3 wires and not shreading the insulation and orange cover more.
Did you find any shavings on the floor when you returned home?
Seriously $1100.00 for splicing 3 wires back together? What am I missing?
Rick
Ford F-150 Lightning Squirrel Chewed Through Charging Wires Screenshot_20250201_075912_Chrome
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
My guess on the repair estimate is that they are replacing the harness. Sometimes a manufacturer will say certain wiring has to be replaced if damaged, that repairing the wiring and connectors is not a recommended repair due to certain factors.
Edit: I see that the OP says they are going to repair, not replace. Yeah, $1100 sounds pretty steep.
BlueLightning
Thomas
Oklahoma
2023 Ford F150 ⚡XLT SR
The other day, I walked out to my truck in warmer (40 degree) rain after a week of sub-freezing temperatures. I saw some chewed up acorns on top of my rear passenger wheel. I instantly had murderous thoughts about rodents. The first few months I had my truck (Sept '22), I had found a mountain of acorns and shells on top of everything behind the access panel in the back of the frunk. A shop vac had cleaned up most of that with no adverse consequences. Well...this time was different.
I got into my truck and started driving and about 5 minutes from home, my watch buzzes at me that I have a message. It says something about powertrain failure as a message from the ford pass app. I didn't have any reduced power according to the dash gauges and the truck drove just fine. I had already forgotten about the squirrel nuts on the tire. I drove it the rest of the day with no issue other than the wrench icon and request that I take it in for service as soon as possible. So I took it in the next morning.
The service advisor told me that they wouldn't be able to look at it until the next day, but because I pointed out some recall work that it needed, he wouldn't have any problem providing me with a loaner.
NOTE: Prior to them determining whether a problem you're having is covered under warranty, they're gambling providing you with a free loaner. I think I'll save up my non-critical recalls for visits like this to ensure I have the best possible chance of being put in a "free" loaner truck.
Last night I got the email from the dealership that it's rodent damage to the charging wires. It's a little over $1100 in estimated cost for them to manually repair the damage (they're not planning on ordering a new harness and believe they can repair it). Once it's repaired, they'll run diagnostics again to determine if there are any more faults contributing to the "powertrain malfunction" and will submit them to Ford if applicable.
For some reason, I decided to overpay for auto insurance 5-10 years ago and only have a $100 deductible. They cover damage caused by animals and it's a no-fault claim. So I'm starting with that route and they don't mind me using the dealership to perform the work. I'll update here as things progress. In the meantime, I'm going to incur the ire of my neighbors by killing some squirrels.
Yep those soybean wrapped wires are delicious 😳😵💫🫣
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
Those damn squirrels. I shoot all of them . 100's in the last couple years. Destructive little vermin. The do keep on chewing because their teeth never stop growing. Started with the plastic base my house air conditioner sits on, then they chewed through the old Chevy Colorado wiring harness. Exactly why I own the Lightning now. Final straw was them chewing on my new hot tub. Bought a high powered .22 caliber pellet gun. Smoke them all Now I have a fox the comes by frequently for a free meal!
Skidrowe
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
They're estimating 5-6 hours of work and their rate is $206 per hour. 3-way splice of multiple wires that require solder, shrink wrap, and retaping. Then there is the time spent root causing, more diagnostics and testing, and putting back together the parts they take off to access the wiring harness. I wouldn't bat my eyes at 3 hours. So while 5-6 seems a little high, it's not entirely out of the realm of possibility. The insurance adjuster approved it.
That picture is from right behind the charge port. You can't get to it by reaching under the wheel well. So it seems like something small had to crawl up there to get to them unless someone took parts off my truck in the driveway, clipped wires, and then put it back together. Also, there wasn't a clear path for the chewed contents to fall to the ground with the wheel well liner. I accept the premise that the damage was caused by a rodent.
evowner
Frank
SW Ohio
Retired EE
But.. but.. they are so cute bouncing across the snow.
FloridaMan655321
1973 F100, 2024 Flash
Had this happen with my old Jeep. It happened after I had parked it outside for over a week while driving my other vehicle. I now try and drive each vehicle regularly as to not let the little guys think they have a lot of time to make a nest.
TreatYoSelf
Colorado
2024 F150 Lightning Lariat - 2020 Tesla Model 3P
Ad Man
My understanding of the problem is that they are using plant based material for the insulation. We had a big problem in our area with our new fiber optic cables being eaten by squirrels.
THIS.
I was told this when a rabbit chewed through a wiring harness for the drive unit on our Tesla a few years ago. I believe it's a soy-based insulation. Required a tow to the service center and $250 to replace the harness.
